Question about HP OfficeJet 6110 All-In-One InkJet Printer
First time trying to fax from this machine
I'm not sure if i have to go through something to set up the fax or where i have to plug it in. Right now i have it on my computer plugged in under line and on the machine it self under line, am i supposed to have it on the phone part. this machine was a used machine and when i try and fax it come back as no answer and and a log number under the person who had the machine before.
    Champion:
  • 320 Answers
The fax machine needs to be plugged into the phone line in the wall in order to fax out
Posted on Jan 20, 2009
I'm not receiving certain faxes. How do I ensure they will all be sent to me?
Dear
Pl. check the memory received., If your fax setting is not done for memory setting i.e. when you receive a fax that immediately printed .Then the fax machine is right some times voice calls also generated if it was given earlier for that or used for voice call, so caller may try to communicate for voice call and got the fax tone (as the fax machine is in auto mode),he simple disconnect the line.
and fax machine may display some error message.
Thanks.
Mar 05, 2015 | HP 640 Inkjet Fax Machine
Just got this and trying to set up...I can send faxes, but can't receive them..I am sure I am doing something wrong. Any suggestions..thanks
Make sure you are using the genuine brother line lead and not an old one from your previous machine. Look at the lcd and it should show date and time and fax at the end. If it does not say Fax then you have not set the auto receive to fax only.
Jul 01, 2011 | Brother IntelliFax-4100e Fax
When recived fax it half the size of A4 paper.but when i send fax ok.
If you are able to make copies ok, I mean you get a full page of the copy, but when receiving a fax you're getting only half a page that could be a problem with the line. First, let's make sure you have all the settings right. Make sure that you have the phone cable plugged in to the port where it says line at the back of the fax machine with the other end going directly to the wall jack. (If that is a digital phone line that you have, the more that you'll have difficulty in receiving faxes, because fax machines are designed to work on analog phone lines only) Also, try turning Off your Error Correction Mode (could be found either on Basic or Advanced fax settings) If you have an answering machine on the same line with the fax, set it to 2 rings lower than the fax machine's number of rings, that way when a call comes in, the answering machine picks it up first, if a fax tone is heard, fax machine picks up. It is not recommended if you have a voicemail on the same line with the fax, if you do, it's either request to turn it off from the phone company or request for a distinctive ring, then set the distinctive ring by accessing your Advanced fax settings.
If you have all those notes above set, and you're still not being able to receive your faxes, let's check on your line. Try to plug the fax machine to a different wall jack and have someone send you a fax, if you receive the fax, then the wall jack where your fax was previously plugged in to must be faulty. Call your phone service provider for the issue.
If you're still having the same issue with the fax, with it plugged in on a diff wall jack, call the customer care hotline for your product.
Apr 26, 2011 | Office Equipment & Supplies
My fax machine stays on and I can't print somethings. Everytime I try to print something the "FAX" machine window opens up....instead of the "PRINT" window. I clicked on the little arrow by the printer...
Try this.. Go to start, devices and printers and you will have a few things listed in there that are related to your printer. Most likely it will say document writer, fax and your hp printer. Make sure that the check mark is on your printer, not your fax. This indicates what your default printer is. To change this, right click on your hp printer and select set as default printer. Once this is set try printing again. Let me know if this works, if not we will try step 2. Hope this helps!
Oct 23, 2010 | HP Office Equipment & Supplies
Not receiving - reports say line busy, I think I inadvertently set something I don't want. Can transmit fine.
Please be sure you have the phone line from the wall plugged into the "line" plug on the fax machine and not the "phone" jack
Oct 07, 2010 | Muratec F360 Plain Paper Laser Fax
Need to set up phone/fax instead of just fax
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
Apr 24, 2009 | Brother MFC-260C All-In-One InkJet Printer
How to set date and time on Canon FAX-L350
Maek sure machine is switched on and there is a display showing.
1. Open the 'one-touch' speed dial panel (plastic flap to right of main number keys)
2.Press the key 'data registration' The display will show "REGISTRATION 1. DATA REGISTRATION"
3. Press 'Set' key twice (lower right key on grey centre panel area). The display will show "DATA REGISTRATION 1. USER SETTINGS" after the first key press, then "USER SETTINGS 1. DATE & TIME" after the second key press.
4. Press 'Set' again, then use the numeric buttons to type in the correct date and time - you should get something like 11/01 2009 and 16:09 in the display (use 24 hr clock for the time).
5.Press 'Set' to save the date and time the display will show "USER SETTINGS 2. UNIT TELEPHONE #"
6. Press the 'Stop' key to return tot he machine's normal 'standby mode' .
7. Print off this webpage so that you can remember how to change the time for daylight saving time changes etc... or int hee vent of a power cut.
Hope this helps.
Aug 12, 2008 | Canon FAX-L350 Plain Paper Laser
Wont' send a fax
In my experience, anything plugged up to a phone line can be some of the most susceptible to electric discharge. Thunderstorms, power surges, brown out, all of these can cripple or kill a fax machine. When I saw this symptom on a fax, 9 times out of 10 it was caused by a power surge of some sort. The line error is most likely the machine's outgoing line has been zapped. The 775 (and it's father, the 770) are some of the most straightforward faxes I have dealt with when it comes to faxing. There is no internal setting that I am aware of that would inhibit the sending of faxes. I would double check the transmission report to make sure that the machine isn't doing something weird like adding extra digits to the numbers you are dialing. It would still be worth your time to try a few things, though. I would plug the fax into another phone jack using a different phone cord if available. Also try using the fax as a telephone, call a number and see if you can connect. If you can, make sure both parties can hear each other clearly. If you can not, the machine will need to be replaced.
Aug 21, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Receiving incoming faxes
# Press the button to enter Fax mode. # Press . # Press the right or left arrow button to select [Receive mode settings], then press the button. # Press the up or down arrow to select the receive mode that best suits your needs(you probably want "FAX ONLY" When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only), then press . # Press repeatedly to return to fax standby mode.
Aug 07, 2007 | Canon PIXMA MP830 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
26 people viewed this question
Ben Johnson
