Question about Bosch Nexxt WTMC 3300 Electric Dryer
Bosch manual for dryer 2004 nexxt premium
How do i locate the small spoge in dryer that dryer down lint vent and u can't see now?
  • 213 Answers
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
call bosch. they are having problems with one of the sensor in that dryer. they try to fix it but in my experiance they end up having to swap out the dryer
Posted on Nov 20, 2007
SOURCE: Squeaks from drum area during operation
We have a Bosch Nexxt dryer and it, too, squeaks during operation. We have not been able to find a permanent solution for this problem although we've had the repairman come out 3 times now. We have however found a temporary solution that lasts for about a week. We spray Static Guard (in an aerosol can) in the inside lining of the dryer... kind of in the lip of the front. (You shuld be able to feel it if you put your hand right inside the door.) We've just been spraying the static guard all the way around that area and the squeaking stops! Hope this works for y'all. May not be permanent but at least it stops the annoying sqeaking!
Posted on Jan 18, 2009
SOURCE: Bosch Nexxt Electric dryer tumbling but not
Unplug the dryer first. Then remove the back cover on the dryer. You will find the red reset button underneath the dryer drum. If the button has been tripped, you will feel and hear it click when you press it in. I would suggest that you vacuum out any dust or lint that has collected inside the unit before replacing the cover.
Posted on Apr 26, 2009
Ranglo
  • 1194 Answers
SOURCE: Bosch Nexxt 500 series dryer, E:01 and lint light
This indicates the sensor near the lint filter gets too hot. This is usually caused by bad air flow.
Try running the unit without the vent hose attached. If the problem goes away the problem is in the ducting.
You may need to have it cleaned out. May be lint filter is clogged due to the use of dryer sheets or fabric softener. You can try to clean the filter with Windex.
If neither one of this suggestions resolves the issue there may be a problem with the sensor, there may be heat escaping somewhere within the dryer. This is only resolved by technician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Posted on Jun 27, 2010
sonicboomele
  • 1557 Answers
SOURCE: my mom's bosch nexxt dryer
in 99% of the case if the unit is running correctly but not heating the heat element is blown and will require replacement.
have a great day
sonic boom electronics australia
Posted on Jan 04, 2011
Why have my dryer stop getting hot to dry clothes?
call an electrician to test the element or if gas call a gas fitter to check the gas operation
May 16, 2017 | Bosch Nexxt WTMC 3300 Electric Dryer
What does E:01 on the Bosch Nexxt Premium dryer mean?
Hello Christie, welcome to FixYa.
I'll start by saying your post indicates it is a Bosch dryer, correct ?
Well the E01 error on these machines indicates an air flow problem...specifically (usually) the lint screen, but can be a build up of lint in the venting as well. Start by checking the lint screen.
This from the horses mouth...errr Bosch ;o)
Following this suggestion should get you back up and running normal. Let me how it goes. If the problem persist's after, I'll try to assist you going forward in any way I can. Good luck.
If this indeed resolves your problem please take a moment after to rate the assistance I was able to provide. Tell your friends to look for "Macmarkus" on FixYa should they need asistance as well. Thank you for choosing FixYa.
Regards,
Macmarkus :)
Sep 26, 2011 | Bosch Washing Machines
My Bosch Nexxt 500 Dryer takes way too long to dry!
check your flex vent hose on back of dryer are go out side your home an locate where the vent come out of your home an see if the air flowing out of your vent, if not you need to pull the dry out take the hose off of the dry an clean the lint out ok, an send me the money you find in the vent ok
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Bosch Nexxt 500 gas dryer takes a long time to dry
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Bosch Nexxt 500 series gas dryer lint building up inside dryer
Get a long brush they have ones made for this chore proably at Ace hardware.
Aug 06, 2009 | Dryers
Lint filter not allowing dryer door to unlock
Try unplugging it for an hour.. Might reset it..
Hope this helps !!
Rate me good ;o)
Jul 13, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 800 series dryer E01 error
My wife has a Bosch Premium dryer that had drying problems. The lint filter would get cleaned but the machine still did not operate correctly, as you explained above. Her machine was made in 2005 and the lint screen, the plastic slotted unit in front of the lint filter was the problem. It gets clogged up with hair/lint that never makes it to the filter. I tried a shop vac to vacuum it but the problem was still there. Get a pistol cleaning kit for a 22 cal gun. Pull the lint filter out & then take the pistol rod and insert it from the drum side into each slot and pull out the tons of lint. Pull the lint off the rod when done and take a flame to burn the rest off as the rod is a brass brush with small wires on it.
Jun 14, 2009 | Bosch Nexxt 500 Plus Dryer
Bosch Nexxt 500 Plus Elect Dryer Error E01
Absolutely those dryer sheets are the root of all evil....I would also recommend a good vent brush to clean your dryer vent.
Follow these steps, it worked for me:
1. use a shop vacuum to clean out the dry vent or a vent brush.
2. Clean your lint filter with windex, hot water and and soft bristle brush.
If this doesnt work try running the until disconnected from the vent for a cycle to isolate the vent as your issue.
Cheers!
Oct 28, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt WTMC 3300 Electric Dryer Logo
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
