Question about Kenmore 73952 Gas Dryer
Gas dryer The runs great except for the gas heater is not working.
  • 350 Answers
If when you run it you smell gas stop running it!
You should shut the gas valve off immediately!
If the gas heater isn't working when your running it it's probably the Valve the activates the gas (Selenoid) or the Ingnitor that lights it!
Posted on Jan 20, 2009
Dryer works great except there is no heat to dry the clothes. Fuses have been checked.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Mar 19, 2011 | KitchenAid KEYS750LQ Electric Dryer
Everything works except the heater
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 22, 2010 | Dryers
I have a maytag gas dryer. It runs great with the exception of HEAT. There is none. Where do I start to look and or troubleshoot this problem.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 08, 2010 | Dryers
I have a 2002 27" kenmore elite gas dryer that runs great except you have to hold down the start button. I took it all apart and cleaned it. The motor looked fine. I think it might be the start button.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Kenmore Dryers
When the dryer is cold the heater flame will
The heating circuit is working perfectly except for the solenoid coils as indicated by the occasional glowing of the igniter but no gas is ignited. A gas valve closes as the solenoid coil weakens as it gets hot and does not open until it has cooled down. Replace both gas valve solenoid coils to get the dryer back into proper operation. The solenoid coils are part numbers 694539 and 694540 but also can be purchased as a kit here.
Apr 27, 2010 | KitchenAid KGYS850LT Gas Dryer
This dryer worked great until it stopped heating
There are four main components for the heater to operate control thermostat, igniter, flame sensor, and gas valve coils if one of this is not working the unit will never heat. That if is gas. If is electric control thermostat most likely needs to be replaced
Feb 20, 2010 | KitchenAid Dryers
I have a roper gas dryer. The Timer stopped
my roper just stopped working this morning the timmer nor the heater or the dryer itself will not at all.
Apr 04, 2009 | Roper RGX4634KQ Gas Dryer
Dryer works gas cuts on and off
Remove the exhaust vent from the rear and run the dryer.
If it works OK..clean the vent internally to the dryer as well as externally.
If this is not a problem or it does the same on/off then:
Replace the gas valve coils. They have gotten weak
Feb 20, 2009 | Kenmore 63942 Dryer
Gas dryer/will not heat
If when you run it you smell gas please stop running it!
You should shut the gas valve off immediately anyway!
If the gas heater isn't working when your running it it's probably the Valve that activates the gas (Selenoid) or the Ingnitor that lights it!
It could be the burner which distributes the gas in which case you would smell gas.
My best guess......the ignitor!
Jan 20, 2009 | Kenmore 73952 Gas Dryer
Kenmore 73952 Gas Dryer Logo
67 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
