Question about Panasonic NN-S543BFW Microwave Oven
Our microwave does not heat and only runs for about 23 seconds and then shuts off
  • Panasonic Master
  • 19,396 Answers
Test the high voltage capacitor, the rectifier diode.or the magnetron. If all this are fine, test the control board.
If it additionally does not spin and no light, then check also the door switch and fuse.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
Bosch hmb5050 shut down after 30 seconds
It may be turning off because it is not heating, does it have the lights inside and the turntable both working?
Dec 10, 2012 | Bosch Microwave Ovens
2003 panasonic microwave runs about 23 seconds and shuts off no beeping just shuts off what could be the problem?
The problem is likely in the keypad control board and since the oven is 9 years old, I would look at reduce prices in the new models, especially when cost of repair comes in the picture.
Apr 04, 2012 | Panasonic Microwave Ovens
I have a Siemens microwave (inno-wave). When I try to cook something, say I set it to cook for 2 minutes, after 23 seconds it stops and reverts back to the digital display clock. It seems clear during that...
The controller is probably sensing that the magnetron is not drawing current and shutting down the timer.
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Nov 21, 2010 | Siemens Microwave Ovens
Switching off after 23 seconds without heating
Hi Paul, did you get any answer for that?? My neff is giving me same problem.. if you know what is the solution can you please e-mail me to alinaseer1@hotmail.com? Regards
Oct 31, 2009 | Neff H5470 Microwave Oven
Amana OTR Convection Microwave runs 59 seconds and shuts off
This sounds like either a thermistor or a damper switch/motor problem.
Amana's technical support line is 866-426-2621. This is the commercial side but they should be able to get you in touch with the domestic side.
Sep 12, 2009 | Sharp R-1850A Convection/Microwave Oven
Microwave does not heat.
HI, this is an inverter board issue. the magnetron would not shut down the unit. if the magnetron was the issue, it would continue to run but, it would not heat.
replace the inverter asap.
Jun 17, 2009 | Panasonic Microwave Ovens
Shuts off after 23 seconds....
In most cases when the microwave stops @ 23 seconds it's the Magnetron which has failed, and is shorting to earth.
Either that or the magnetron isn't getting the right signal from the inverter board. It gives it 20 seconds to get the right signal or it shuts itself off.
Apr 04, 2009 | Panasonic Microwave Ovens
My Panaosmic microwave model number NN-S543 just stops after running for 23 seconds. It was running fine for the past 5 years and suddenly yesterday this problem starred. Even the 23 secconds it runs there...
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 05, 2008 | Panasonic Microwave Ovens
Panasonic NN-S533WF Microwave
because of high voltage circuit thats happend ,please check highvoltage circuit may be short circuit or any companent burntout. check magnetron and high voltage diodes etc.
Sep 29, 2007 | Microwave Ovens
Microwave Ovens Logo
129 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
