Question about Impact Central Pneumatic 12" Pneumatic Wrench
1/2 air impact wrench. loss of power.
It loss 2 screws and was acting likwe it wanted to work and then it stop under presure of a tork. when i got it home to check it out on my own air compresser it begain to loose power. in the head. like. it works forward and reverse, and the tork setting works but it don't have power or full rpm status.
5 Suggested Answers
  • 5 Answers
SOURCE: Impact wrench never stops spinning!
you have a bad o-ring at the air inlet
Posted on Apr 25, 2009
mitchbtu
  • 121 Answers
SOURCE: I need the manual for my Husky 1/2
Home Depot carries Husky products, Id start with them...
Posted on Jan 24, 2010
HansPP
  • 2510 Answers
SOURCE: I have a husky impact wrench, set at 100psi, but
There should be an air control valve adjacent to the air inlet, is it opened sufficiently. Failing that there is a problem with the drive motor. It could be seized bearing or a broken vane. There is nothing you can really be doing wrong, it is a very straightforward tool.
Posted on Jan 27, 2011
SOURCE: how do i oil my husky air impact wrench?
if its like most of them it goes in the air chuck just a few drops i belive or theres a set screww at the under side by trigger more to the frount not 100 % sure
Posted on May 09, 2012
Impact turns but no tork why
An impact wrench works by directing air into a chamber where a hub with sliding vanes turns to do your work for you. If any of the five or six vanes are damaged the tork value will go down. It is possible for the hub to turn freely however the more air that gets past the vanes, instead of pushing on them, the lower your tork value will be. The bearings for the hub could be damaged or seized but that usually affects free spinning speed more than tork. The insides of an impact wrench are fairly simple, take it apart and check the vanes and bearings. Ingersol Rand makes rebuild kits for most of their impact wrenches.
Aug 17, 2012 | Ingersoll Rand Ir 2131qt 1/2 Impact Wrench
My CP impact wrench run fine when not removing a bolt. When removing the bolt it turns it a few rounds then stops
Try a good cleaning with diesel fuel. Keep adding diesel into air inlet until the fuel comes out clean (add diesel then connect air to blow it out) . Once clean, add several drops of oil and retest. If it works better but not full power, try another cleaning with wd40 and retest. Good luck
Oct 16, 2011 | Chicago Pneumatic 1/2" Air Impact Wrench
Oiled and still runs slow
Vanes in the air motor not sealing well
Aug 01, 2011 | Ingersoll Rand 1/2? Heavy-Duty Air Impact...
My CP 734 has no power under load. Is there a rebuild kit to fix this problem and where can I get it? If a kit is available, is that a difficult rebuild? Tim
I used to repair these impacts for a living. Simplest first thing to do is back off the three 1/8" set screws in the back a couple turns. Pour a little varsol into the air inlet and plug it in. run the gun until your hand is black, (wear a glove). Once the varsol stops disconnect the air, add a few drops of air tool oil and tighten the screws slowly and evenly. You will hear the impact rpm increase. If your gun doesn't speed up to it's original scream you will have to remove the four 5/32" set screws and see what's worn. To open it hold the impact by the nose 3" off the table and position a center punch in the hole of the anvil shank with the same hand and hit it with a hammer hard enough to overtake the spring. The guts should drop on to the table in tact. The guts are in twp parts, the hammering mechanism, and the air motor. The three 1/8" screws hold the motor together. You will soon see the problem. Take the back off the air motor and it will show your if the veins are worn. Cjeck the end plates for wear. You can turn the end plates down on a lathe if available. As a rule of thumb, if the anvil shank is dry buy a repair kit, if it's wet, buy a tune-up kit. If the ring on the anvil shank doesn't turn, buy a repair kit and change your sockets. When rebuilding these front seal often leaks. These impacts are supposed to use 30 weight oil, but a mix of Ingersol Rand grease and 30 weight oil, ( just till it's slightly runny) will stay much longer. Assembling the anvil assembly can be tricky until you figure out how to hold the shank and two pins with the same hand. Good luck.
Dec 04, 2009 | Chicago Pneumatic 1/2" Air Impact Wrench
Craftsman 1/2 inch impact wrench,not working
Make sure you have at least 90 pounds of air and if you do you need to oil the wrench air tool oil pour some in the where the air line hooks up ..air tools need to be oiled daily cause compressed air cause water vapors to build up when you use it and then when it sits it begins to rust a bit and the oil stops this ...
Nov 14, 2009 | Craftsman 1/2" Impact Wrench
Air leaking from around power control knob at rear when used-CAUSE? Has been professionally overhauled and still happens.
air is bypassing threw the o-rings, or rotor vanes, even if rebuilt does not meat the barrel is wore out, does it have any tork to it? is it comming out of the shaft or the screw shaft barrel that is leaking?
Jul 06, 2009 | Tools & Hardware - Others
Apr 16, 2009 | Impact Husky® 1/2" Wrench
Air Wrench Question
An impact wrench works in the manner suggested by the name of the tool: through the principle of impact. In order to understand how an electrical or air-powered impact wrench works, it helps to know first how a manually powered impact wrench operates. A manually powered impact wrench looks like a fat screwdriver; on the end where the screwdriver blade normally goes, you can snap on screwdriver bits or sockets.
Aug 27, 2008 | Ingersoll Rand 271 Super Duty 1 Inch...
Impact Central Pneumatic 12" Pneumatic  Wrench Logo
61 people viewed this question
Top Impact Air Tools & Compressors Experts
Vernon Taylor
terry stevens
Are you an Impact Air Tool and Compressor Expert? Answer questions, earn points and help others
