Where can I purchase a replacement sensor for the pilot light?
  • 51 Answers
If you mean the theromocouple for a water heater or a furnace you can get them at lowes. they sell a universal one and fits most water heaters with pilot lights. they cost about ten bucks there.
Posted on Jan 06, 2013
Pilot light will not go on unless it is lit manually. At this point the fireplace will light up, for about 30 seconds and then all shuts down
There is a flame sensor for the pilot light that keeps the pilot light gas flowing from the main gas valve. If the sensor is too far away from the flame, it will stop the gas valve . The sensor itself can fail in time, so it may need to be replaced.
Dec 06, 2016 | Heating & Cooling
Belling gas oven will only work when holding in ignition
The oven piot light heats a sensor which keeps the pilot light burning after releasing the button. The pilot light flame must be sensed by the sensor, the sensor must be in working condition. Replace the sensor or make necessary adjustments to make the pilot light flame burn on the sensor. The sensor is either a thermocouple or a generator. Thermocouple is standard, a generator needs to be properly matched with its type rated in millivolts, same rating for the replacement.
Feb 10, 2015 | Belling Kitchen Ranges
Gas dryer pilot light won't light, stay lit
The pilot light has a thermal sensor above it to determine if the gas is burning or not. If the pilot light goes out, it cools and then the gas line automatically closes so that you don't get a constant stream of gas. When the sensor dies, the same thing happens -- no gas for the pilot.
Replace that sensor.
Mar 05, 2011 | Dryers
How to replace a pilot
Probably no need to replace pilot. Just clean it. If your Raypack (mine is a 2100 but most have the same electronic ignition pilot) lights and runs for about 2-5 minutes an then shuts off, you need to clean the pilot sensor. The pilot sensor tells the unit the Burners are running. If the pilot sensor becomes corroded, carbon, etc. the unit will light but will shut off after a few minutes as it thinks the unit is not operating properly. The unit will try to re light, but fail, and then PLT will show on the main programming screen. To fix the probelm, shut off the unit power. Remove the pilot assembly which is located at the bottom right of the unit. There is one screw holding the pilot assembly in place. Gently remove the pilot assembly. There is a fork like probe sensor (not the one with ignition and gas feed) that needs to be cleaned. Take some rough sand paper and clean it thoroughly. Re insert pilot assembly and fire the unit. If this fails, clean the sensor again. Problem solved!
Sep 21, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pilot light does not stay on.
Be sure to keep the button pushed for 45 seconds AFTER lighting the pilot. If the pilot continues to go out, the problem is most likely the thermocouple. A replacement thermocouple can be purchased at the local hardware store for under $20.00.
Mar 23, 2010 | Heating & Cooling
The pilot light will not stay light
The flame sensor is not sensing flame. If it is a thermocouple sensor, they can be purchased for 6 bucks and replaced in 15 min.
Some units have a different type of flame sensor and are a part of the ignitor assembly. In that case, the ignitor assembly would have to be replaced. Those usually run 20 to 60 bucks.
There is a remote possibility that the sensor and pilot flame shroud need to be cleaned, due to rust and other corrosion preventing the flame from properly contacting the sensor. You can try cleaning that first, but chances are you will simply have to replace the sensor.
Oct 11, 2009 | Water Heaters
Pilot light will stay lit Lennox G8D2-82
You may need to replace the Thermocoupler. It screws into the gas regulator and the sensor end is set in the flame of the pilot light. You can get one at any appliance parts store. The Thermocoupler simply feels the heat of the pilot light and sends a very small amount of voltage to the gas switch that opens when your thermostat calls for heat. If the pilot light isnt lit, no voltage from the sensor and no gas can be released by the regulator.
Anyone can replace one. Just find the tip that sits in the the pilot flame when you try to ignite the pilot light. Follow it down to the regulator and unscrew it. There is no gas involved. It is Ultra Low Voltage. No danger.
Be sure to turn off the power to the unit before you begin removal. Take it to the parts store along with your furnace brand and model number. If you see any identifiers on the regulator, note them and take them with. When you replace it be sure to have the sensor end up in the flame of the pilot.
Sep 29, 2009 | Heating & Cooling
HEATER AND PILOT GOES OFF AT TIMES
Sounds like your oxygen depletion sensor is shutting your unit off. The problem with fixing your unit is that it may cost you the same to purchase a new one (assuming you pay someone to fix it).
Feb 16, 2009 | Procom ML060HPA Heater
Burner and pilot run then kick off
if this is electronic ignition you have a dirty flame sensor.
If you have a standing pilot light you should remove, dismantle and clean the pilot assembley.
Makec sure you clean the small gas oriface located inside the pilot assembly.
When you put it back together I would install a thermocoupling. Can be purchased for about $10 -$14 at any hardware store.
Jan 06, 2009 | Heating & Cooling
My pilot light won't stay lit
its possible you have a bad flame sensor or thermocouple. this is the least costly repair. in fact thermocouple usually can be purchased at local hardware stores and replaced easily. if that doesnt fix it then you have a bad pilot valve and will need to have a certified gas technician fix it for you..
Dec 19, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
