SOURCE: Delta luv crib hamptons 3 in 1 crib manual
I was looking for the same thing. My crib has directions on the board that the mattress sits on. It basically says to remove step 4, which is the rail that goes up and down. You slide it up a little from its bottom position and then the screw heads come through the slots that you see and then the whole thing comes off pretty easily. I has to push and pull a little to get the screws through but it worked fine. There is no additional piece that goes on, just stays like that and is stable. My son is very excited to give it a try tonight. Sort of a long way down though! Need to find some extra pillows for a safe landing! Good luck to everyone.
SOURCE: Delta Enterprise Versailles 4970 Crib assembly
call delta and they should be able to send you a manual, just tell them you never got it with the crib (manuals are usually free)
SOURCE: delta 5 in one crib and bed missing lower guide
I was able to call the manufacturer and get the information and parts that I needed. Thanks!
SOURCE: Need Instructions For Delta Luv 3-in-1 crib Model No.4580
I have the same crib and the instructions are on the bottom of the mattress board. Mine states to remove one side to make it into toddler bed.
SOURCE: I need instructions for a Delta convertable crib
http://www.deltachildrensproducts.com/pdf/81001_PADRONA_Combo.pdf
