My washer fills until it overflows...when I turn the dail to the wash cycle, it just drains and spins...
  • 61 Answers
Most likely the water level switch broke or water level hose came loose, if the washer keeps on filling on after you turned it off, then is the water valve. Which brand is it?
Posted on Jan 20, 2009
What controls the water cut-off feed during cycles and when dail is set in off position.
There are electronically turned on and shut off water valves that are controlled by a water level sensor which varies based on what load size/water level you need Small, Medium, or Large. So if the valve gets stuck open since it's an old machine, the water will just keep coming in. But let me ask you this? If you turn the house water value on n NOW...will the wash machine just start filling? If so, it means your valve is stuck open so you would need to replace the water valve which is like $50 online. If the house water valve is on, and when you start the washing machine it starts filling, but just keeps on filling...that's probably because your water level sensor is messed up. So you have 2 things to check...is it the washer water valve is stuck open? or is it the water level sensor that isn't sensing when the washer is full so it just keeps filling it.
Dec 21, 2017 | Home
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Water Overflows from washer
Hello,Sounds like a problem with either the inlet valve or the pressure switch, way to determine which on is while it is filling pull the plug..if water keeps filling it's the inlet valve..if it stops filling it's the pressure switch..If you have any other questions or concerns please feel free to comment again..good luck!! Mike
Aug 18, 2009 | Kenmore Washing Machines
Stuck in spin
Hi!
If the Washer is stuck in spin then either the timer or a cold-water supply problem is causing this :
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance, then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
Do rate the solution as FixYa and revert for further clarification.
Thanks
Rylee
Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
