Question about Janome 2049LX Mechanical Sewing Machine
Error 5 on my machine
I was sewing an suddenly the machine made an awful noise and the screen showed ERROR 5. I took the thread out and tried rethreaded it, turned it off and back on again.
  • 3 Answers
Can I get a copy of the instruction manual for your Janome Harmony 2049? I got my mom's machine when she passed away in Dec but no manual. Thank you!
Posted on Mar 31, 2008
SOURCE:
What is an error 5 on baby lock Grace
try adjusting the top thread tension
also try changing the needle-one that is for the fabric and thread
if that doesn't help, then a repair shop would be a good idea
Apr 05, 2014 | Baby Lock Sewing Machines
Is there a code to fix a singer sewingmachine when it flashes 88
I just found your question, so I'll try to help you,
you said you just had the machine serviced and it's still
showing the error 88, is this error why you took the machine in to
be serviced for?
if it is then I suggest taking the machine back to the repair shop
and tell them it wasn't fixed correctly.
I've had other people say that they've took their machine in to be
fixed and then brought the machine home and it still had the same
problem so that means that they didn't fix the machine ..
have you tried changing the needle--needle that is correct for the
fabric being sewed
try rethreading the machine top and bobbin
also try using a different bobbin
make sure the top thread has not come off the thread take up lever
make sure the top thread is not wound around the spool pin
make sure the bobbin is turned the correct way
do you have a manual for the machine?
Dec 19, 2012 | Singer 7444 Mechanical Sewing Machine
Singer quantum futura ce200 - thread breaks
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Feb 06, 2012 | Singer CE-200 Quantum Futura Computerized...
I attached the walking foot , but the needle will sew through the fabric
this is what my instruction book says
Lo---a button is pressed when the machine halts due to overload
wait for at least 15 seconds to recover
if thread jamming causes overload, remove the tangled threads
Jan 17, 2012 | Janome Memory Craft 9000 Computerized...
The lower thread does not bring up , so that the uper thread does not come in contact with the lower thread .I hear unusaul noise while sewing.All these happend when I tried to sew a jeans .i used a thread...
As a general rule, domestic machines don't like buttonhole twist, that heavy yellow thread you see on the RTW jeans. Sometimes you can put it through the bobbin but use a regular weight thread on top but this means sewing upside down as you'll want the yellow on top. And lots of machines dont like different weight thread top and bottom so it just makes for awful stitching anyway.
Best solution to top stitch jeans is use a regular weight thread, large size jeans needle but thread up two spools of thread on the top with both threads going through the same needle eye. It still may not solve the problem though.
To your machine, firstly change the needle as it may be bent. Then unthread the machine and manually turn the flywheel through a stitch cycle and listen carefully, if you still hear a noise as the needle touches the rotary hook, you've knocked the timing out. Service man visit time.
Probably if you check the manual, it will say 50 weight thread, and you'll need to stick with that in the future.
Those big industrial sewing machines that they top sew jeans on are very different to a domestic SM, many make a chain stitch or fell the jeans seams and are very heavy duty.
Jun 05, 2011 | Toyota STF17 Sewing Machine
I am trying to use a twin needle, however, every time I begin sewing the machine makes a very unhappy sound as though the needle is being blocked as it tries to pick up the bobbin thread. I have tried ...
check to see if the twin needle are damaged
check the bobbin & make sure the bobbin case is thread correctly
needle & thread may not be compatable
here's how to check
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 01, 2010 | Brother XL-2600I
Big wad of thread on back of material, makes a god awful noise. It is new and we are new to it.
You have to read your manual carefully, then rethread your machine because it is not threaded right. If, you need extra help call 1-877-276-8437 until 5:45pm est
Sep 04, 2010 | Brother Sewing Machines
Janome 2049LX Mechanical Sewing Machine Logo
256 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
