Question about Toshiba 57H81 57" Rear Projection Television
57HX81 Toshiba. picture gets squiggly on dvd input
My TV works great other than when I switch the input to play dvd, the screen gets squiggly and picture is not viewable. not the dvd. tried another tv and the dvd's play. Any ideas what may cause this and how i can fix it?
thanks!
    Sergeant:
    Champion:
  • 267 Answers
YOU HAVE A LEAKY CAPACITOR. IT CAUSES THE SET TO LOSE SYNC. EST $325.00
Posted on Jan 23, 2009
    Habit-Forming:
  • 28 Answers
Perhaps 2 things. Does TV get a picture without DVD connected? If so I would bet you have a faulty connection in your signal board where the in jacks are at the back of the TV . Check to make sure cable from DVD are not bad, I have used cables before and got a false positive. Try turning and spinning the jacks once you have a picture.Make sure your signal board is firmly pressed into its slot on the signal board chassis. Thats it for now. Good luck.
Posted on Jan 22, 2009
Cant get it to show a picture
Could be how you have it connected and what input you have your TV on. Also, if this is a TV that is an extra DirecTv might not allow it viewable. Ok, I have a three TV setup with Dish - One controller box per TV - If this is similar, then this extra TV may not work with out some kind of work around. My living room TV is set for HDMI 1, Xbox is HDMI 2, BlueRay/DVD is HDMI 3 - So make sure your TV's feed from the source is being received.
Have a great night
Mar 26, 2016 | Emerson LC320EM9 32 in. LCD HDTV
How to use the dvd player how to play a dvd how to get a picture
should be with the remote---whatever input on the rear the unit is connected to you have to switch the set to THAT input to see the DVD
Oct 31, 2012 | Televison & Video
Vizio VW46L10 TV has a 6 inch dark band across the top of the picture.
Change input device to some other like a DVD player.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 02, 2012 | Televison & Video
Not sure if this is the tv or what. Was watching this tv yesterday. Then suddenly all other channels except for the one I was on either had squiggly colored lines or 3 mirrored versions of the picture. Now...
Does it happen on other inputs? If so, reset the tv, sat or cable box, unplug power and try again. Play a dvd. Does it happen on a dvd? If not, there is an issue with your cable source. If it shows on dvd too, contact your tv manufacturer. You need a repair.
Jul 27, 2010 | Sony KDF-E42A10 42 in. LCD Television
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
Lightning mcqueen tv and dvd set-up, won't play, have direct tv hook-up
i guess there a built in dvd player on the set and it could play most DVD format.
but if you wish to use another dvd player
hook up the dvd on the tv
video output (DVD) to video input (TV)
audio output to audio input
the find the auxiliary button from either the tv or dvd
Oct 30, 2008 | Disney DTD1363-CAR 13" TV/DVD
Prima HDTV has a black screen on TV, but works fine while Playing DVD
try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
Oct 22, 2008 | Prima C2012 TV
Cannot get dvd to play on tv, no picture, try different channels, etc.,
on you tv must be a button "video/tv",you have to push this many times to find front, back or video1 or video2 (depent were you plug the dvd)and there is were supost to work. no on channel 3 or 4
Oct 21, 2008 | Disney DTD1363-CAR 13" TV/DVD
No Picture on TV
? What is the model # off the back ?
Does the video work on the RF coax cable input?
For instance,as a test,can you hook-up from VCR coax RF out
to TV coax in,put the TV on Chan. 3,play a tape and get audio and video?
Are you matching colors when trying the A/V inputs?Yellow,red,
and white out of DVD to yellow,red and white in on back of TV?
Then select video input on tv===dial "00" or use input button on
original RCA remote. Are you using original RCA remote that
came w/TV ? Do you have the owner/operator manual for the TV?
   Sorry to ask so many  ?????   Let me know how it goes!!  T.
Oct 17, 2007 | Televison & Video
My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
Oct 15, 2007 | Televison & Video
Toshiba 57H81 57" Rear Projection Television Logo
85 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
