Question about Maytag Kitchen Ranges
Model #: WFE510S0AB f9 code
Electric range getting code F9
  • 213 Answers
SOURCE: F9 Display in Model MGR5770ADB Gas cooking range
f-9 means you either have a bad door latch hinse the light staying on, or the ERC which is the oven control has a stuck relay and youd have to replace the ERC to fix it.
Posted on Nov 27, 2007
  • 46 Answers
SOURCE: F9 Code after power outage - Model JGR8855ADS
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Generic:
Fault Code Interpretation Components To Check
F-1 Communication error between touch pad and ERC (clock)
Replace the touch pad or clock.
F-2 Oven temperature sensed by electronic control Replace the clock/relay board
F-3 Open oven sensor or harness. Replace the oven sensor
F-4 Shorted oven sensor or harness Replace the oven sensor
F-5 Power to element relay disabled in cook mode Replace the clock/relay board
F-7 Shorted touch pad key sensed for 32 secs. Replace the touch pad/control panel
F-8 Shorted meat probe Replace the probe jack.
F-9 Door lock safety circuit on ERC sensed Replace the door latch assembly
F-C or F-0 Communication error between boards Replace the relay board
Maytag-Maycop-Magic Chef-Jennair-Admiral: Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Posted on Mar 10, 2008
  • 1314 Answers
SOURCE: Jennair 8855 F9 error
take a 24 inch peice of coat hanger make a small u in one end and insert it from the left side gentlw fish for the door latch hook and pull it over to un latch the door and let me know if the code goes away
Posted on Jul 13, 2008
Dipu007
  • 2110 Answers
SOURCE: F9 on Maytag range MGS5770ADB
Posted on Dec 23, 2008
SOURCE: F9-6 fault code on maytag gemini double oven range
I waited until the next morning and hit the cancel button. It cleared the error
Posted on Sep 17, 2009
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
F9 error
the F9 error code means that you have a problem with the door latch assembly in your range. The specific technical information on this failure in your model of Frigidaire range is shown in the image below. If you can clear the F9 by using the troubleshooting steps shown below then your range may resume normal operations. If the CLEAR key does not eliminate the F9 then you will need to try unplugging the range for 30 seconds. If the F9 returns when you plug the range back in, then you will need to replace the door latch. Here is that part to order.
To continue to troubleshoot this problem yourself, then you will need to unplug the range and check the wiring between the door latch assembly and the electronic oven control board. Remove the back panels to access these components. NOTE: Internal metal edges and the sides of the back panels can be sharp.
Feb 13, 2013 | Frigidaire PLEF398AC Electric Kitchen...
I was baking at 350degrees. My oven turned itself off and the error code F9-3 is flashing. please assist if abe.
The F9-3 error code means that either of the two oven self clean latches is stuck so ya need to check and see in both ovens if their is something from obstructing the lacth
if you also get a F9-4 that would mean its just the lower oven
a F9-5 would be just the upper oven
but for the F9-3 it could be either oven
Aug 28, 2011 | Maytag MER6772 Gemini Electric Kitchen...
A maytag Gemini everything is working but it is flashing an F9-5 code and sometimes it throws a F9-6 any ideas on what to do????
Hi twiztedminds,
The F9:-5 / F9:-6 error code description is Latch Unlock Lower. Check for obstruction in door lock mechanism.
Hope it helps.
Thank you for using FixYa.
(Positive feedback will be greatly appreciated.)
Aug 09, 2011 | Maytag MER6772 Gemini Electric Kitchen...
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
Getting Error Code f9-5 and f9-6 on MER6770
This is a bad electronic clock assembly and it is very simple to repair. You can save a lot of money by making this repair yourself, too!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 7 PM CST and we will get the correct part, as well part removal/installation instructions to you .
We look forward to working with you. Thanks, Ella
Jan 18, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Maytag range fault code F92
There should be some number after the F 9 Error code. And, it would look like this
F9-1 Latch lock upper
F9-2 Latch unlock upper
F9-3 Latch lock lower
F9-5 Latch unlock lower
F9-6 Latch both lower
This is just to give you an idea. But one thing you can try is UNPLUG THE UNIT AND LEAVE IT LIKE THAT FOR AN HOUR OR TWO, AND THEN PLUG IT BACK IN.
Jan 08, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Kitchen Ranges Logo
70 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
