Need to replace water hose on washing machine. Hose that releases water out of the machine. Older model Roper top load; model AL413VW1
  • 90 Answers
Try doing a search of your particular washing machine model. This may give you resources to different parts and supplies. Also, you can try www.repairclinic.com and see if that site can help you out. Good luck with your endeavor.
Posted on Jan 20, 2009
I have a Roper washing machine and it will not drain the water?
Most common causes for a machine that won't drain are:
  1. Clogged drain tube
  2. Clogged drain hose
  3. Clogged drain pump
To diagnose, remove the drain hose from the drain tube and look for water in the tube. A clog will force water back into the machine. If this is clear, some debris could have worked it's way into the drain hose itself. Check this by removing the hose and inspect for a blockage. If both are fine, the problem is most likely in the drain pump. Many times, a piece of paper left in a pocket will work it's way into the drain pump and get lodged.
Mar 31, 2011 | Roper RAS8445KQ Top Load Washer
My washing machine is a Roper top load washer. The problem I am having is that the pump from the cold water drain from under the washing machine. Do I need another pump? The hot water will work. I use the...
This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
Hope this helps
kcomp1863
Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
Washer wont stop filling as the cycle cintinues
Check the plastic hose going to the water level switch.
It may be pinched.
If the plastic hose is OK,replace the water level switch.
Jul 16, 2010 | Roper RAX4232KQ Top Load Washer
My roper wash machine is leaking. is it worth
check when it's leaking during the cycle.
If the fill hose has become unhooked from the outer drum of the machine, it'll just dump water all over the floor... it'll leak out of the case of the machine, but it's an easy fix... you simply open the machine, reinstall the hose into the drum or you may have to replace the hose...washing machines will last a good long time...it's worth the trouble to fix...let me know if you need help opening it up.
This can happen if the machine is overloaded... I had a laundromat and this happened alot because people were cheeeeep and wanted to overstuff the machine thinking they'd get a better deal...not true...dirtier clothes and broken machines....
Aug 05, 2009 | Roper RAB2121KW Top Load Washer
Roper RAX 5133AWP WASHER WONT DRAIN
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Jul 12, 2009 | Roper RAS8445KQ Top Load Washer
No cold water will enter machine but not water
Turn off the cold water.
Remove the cold water hose from the washer. Clean out the filter screen in the water valve. Re-attach the hose and turn the water back on. If you get no cold water replace the water valve.
May 01, 2009 | Roper RAS8445KQ Top Load Washer
Water overflows...does not shut off when full.
Empty tub of water unplug unit and pull it away from wall about three feet, tip unit back and on right side of drum you will find a hose connected to it remove this hose and inspect it for clog,if no clog is found nipple end on drum is probably clogged"can be cleared with small wire".If this is not cause then presure switch in upper control panel is bad,"note if hose is not connected to drum that is cause".The pressure switch is connected to the hose and the hose can even be damaged with hole in it if this happens hose needs replaced the length of the hose is important to operate properly and should not be altered in any way.
Apr 20, 2009 | Roper RAS6233KQ Top Load Washer
Top load roper washer water will not cut off after filling machin
The water valve is the part where your water hoses connect.
Replace the water valve if the water is constantly running after the machine has been turned off.
If it only overfills during the fill cycle, check your water level switch and connecting plastic air pressure hose.
Mar 08, 2009 | Roper RAS8445KQ Top Load Washer
Washing machine releasing water at wrong time
your drain hose is to low ,,make drain hose go up the height of machine berfoe it can come down,,,sphion effect...onthejob
Jan 14, 2009 | Maytag PAV2300 Top Load Washer
ROPER TOP LOADING WASHING MACHINE
Check the lint filter at the end of the hose. The filter is actually inside the washer. My husband cleaned it out and now ours works great. Both hot and cold had stopped running in because of our hard water.
Sep 20, 2008 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
