SU-V96 Integrated Amplifier - Audio Players & Recorders
petraman7
  • 1175 Answers
SOURCE: Technics su-Z750 Intergrated Amplifier stays in Standby
HI...
This happens when one or more components in the power amplifier section has failed.
The protect circuit keeps large DC voltages off the speakers.
The only thing you can check for before finding a tech is that the speakers are firmly connected at both ends. If they are ok, you need a tech
PLease rate my help if this helps
Posted on Nov 09, 2009
perkoo
  • 17 Answers
SOURCE: Technics Integrated amplifier su-v85a speaker
test you speaker maybe there is a bad connection some where is the spk. box its self ,try changing speakers left to right .
it the spk. are ok open amp see all the connections within the amp .
if this dose not work contact me by mail: starilaz@net.hr
Posted on Dec 21, 2009
caroldon
  • 17130 Answers
SOURCE: Techics new class A digital integrated amplifier
Is this happening in a regular pattern. If so please check from the mains power section.Check from the plug, the socket, use another outlet if possible to check. If the faultt recurrs, then you willneed to open the set when it trips off, check all the connectors, the main PCB for any signs of bad joints caused by dry soldering in heating sections. If so use a good iron to resolder these sections bbut attempt only if your familiar with these circuits. Next notice if there is any excessive heating when it is cutting off, if so reduce the treble and bass to confirm any transcient noise running the amp.Use another source to recheck if the noise is coming from the present one. I hope this helps. Good day
Posted on Jul 19, 2010
xxmartyxx
  • 12 Answers
SOURCE: my su-g95 technics Stereo integrated amplifier
Well it sounds like your amplifier IC's are working correctly since you are hearing that pop. I have the same amplifier and every 10db increment it pops. Have you tried every input? Possibly try starting at a low volume, plug an RCA plug into CD or any other input, and touch the center prong of the other end of the cable. You should get a 60hz hum if your in the USA, otherwise it will be 50-55hz. Regardless it should make noise.
Posted on Nov 18, 2011
Grubhead
  • 5151 Answers
SOURCE: I have a Technics SU-V460 Integrated Amplifier that won't stay on....the power button doesn't stay pushed in. When I hold it in, it works but the button makes a crackle sound.
It sounds like the switch might be broken. It might need to be replaced.
Posted on Dec 09, 2012
My repairer just misplaced the ic for stereo integrated amplifier su-v50 class AA. So please help me with the ic number
A search with Google shows no such number. If this is truly a Class A amplifier, in my experience, there are no output ICs. Even so, unless they process both channels in one IC, there would be a complementory IC on the other channel.
Jun 26, 2015 | Audio Players & Recorders
How do I fix my integrated amplifier Su g75 it
It sounds to me like you blew the output transistor(s). Best take it to a service shop.
Oct 01, 2014 | Audio Players & Recorders
Technics SU-G75 overload
I have the same problem..it will be required to remove the board and resolder "cold " solderings... None of above solutions have been helpful, but "you get what you paid for"..and I completely disagree...even if required, remove ALL audio power managing circuitry and replace this expensive original design with TI´s Integrated chips..using PWM technology..unless you want to go back to L6, ot Kts tubes..
Nov 07, 2012 | Technics SU-G75 Amplifier
How do I hook up a stereo reciver to the technics su-g91
I assume you want to use the SU-G91 as a power amplifier to drive your speakers. If your receiver has connections for inserting an equalizer (may be labeled pre-amp output and power amp input), remove the jumpers between the pre-amp and the power amp, then run cables from the pre-amp to the SU-G91 inputs. You can have an equalizer between the receiver and the integrated amplifier.
If this is not available, use the recording output (for a tape recorder on older receivers). Note that the volume control on the receiver will be bypassed with this connection.
Sep 23, 2012 | Audio Players & Recorders
What could cause intermittent no power to amplifier relay (RLY551) in Technics SU-V96?
Check the relay control transistors. Check the voltage at the collector and base of this transistor. Download the service manual to your device to get more details.
May 26, 2012 | Technics Audio Players & Recorders
Technics Integrated amplifier su-v85a speaker volume fluxuates and speaker left shuts down some times what is the problem?
Oct 12, 2009 | Technics SUV500 2-Channel Amplifier
54 people viewed this question
 Grubhead
Grubhead
