Question about Casio Exilim Card EX-S600 Digital Camera
Lens on Digital Camera won't r retract
My Casio Exilim ExZ50 was dropped with the lens extended..and now it won't retract. What can I do?
  • 374 Answers
Send into Casio Repairs. Call them at 800-706-2534 and keep choosing option 1. If you have to lie and tell them you already talked to tech support otherwise they will try and tell you to call tech support and they will just tell you what I just did. LOL
Posted on Jul 08, 2007
Camera turns on lens extends then lens retracts and camera shuts down
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here's a video summary of some of the steps (note that the above link provides additional tips that go beyond those shown in the video):
Nov 24, 2011 | Casio EXILIM Card EX-S770 Digital Camera
My casio exelims lense wont retract. what do i do?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 28, 2011 | Casio Exilim EX-Z750 Digital Camera
Lens will not retract properly. showing lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jun 18, 2010 | Casio Exilim EX-Z57 Digital Camera
Lens error . dropped camara and lens opened and now, when i turn on the camara, lens is open and screen says lens error
does it not extend or retract properly? Try to unstick the lens by gently pushing it in or pulling it out a little bit. IF that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Apr 26, 2010 | Casio Exilim EX-Z750 Digital Camera
Lens error of casio EX Z300
The lens error is usually caused by mechanical faults concerning lens assembly. This happens because there is dirt inside the lens (sand dust), or one part in the lens assembly is bad or went out of place.
Because of this he lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
If if does not extend tapping gently the back of the camera, and if it does not retract helping lens back in while turning camera respectively on and off.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 18, 2009 | Casio EXILIM EX-Z300 Digital Camera
Casio Exilim EX-Z60 won't turn on
This happened to me too, fiddle with the lens as its obviously stuck. Don't be too rough but try to figure out if it is slightly bent.
You will only be able to this if the lens is sticking out a little, enough to get a grip.
Good luck
Apr 12, 2009 | Casio Exilim EX-S600 Digital Camera
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 27, 2008 | Casio Exilim EX-Z50 Digital Camera
CASIO EXILIM EX-Z700 Lens Error
The only way to fix a lens error is to send it into repairs. Call them at 800-706-2534 option 2 and they will tell you the closest place to send it to.
Sep 14, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
"lens error" on casio ex-z3
Sorry to say but a lens error actually is a problem that you cannot fix at home. When a lens error occurs, the motors inside that make the lens retract and protract were some how damaged, usually caused if the lens try coming out when you have it in your pocket or against a surface so it cant fully come out. You will have to send the camera in for service and you can do that by calling 1-800-706-2534, option 1.
Oct 19, 2006 | Casio Exilim EX-Z3 Digital Camera
Casio Exilim Card EX-S600 Digital Camera Logo
90 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Ron Grant
Level 1 Expert
Are you a Casio Camera Expert? Answer questions, earn points and help others
