Question about Philips Audio Players & Recorders
Unable to fit standard sd card into Phillips pv7005 media player
Miniature sd card slot only. On player
SOURCE: Unable to download songs onto SD card
umm i just want to learn how to put stuff onto my sd then on my wii
Posted on Sep 22, 2008
LadyTrail
  • 3 Answers
SOURCE: Additional SD card memory installed in the card slot
Check to see if it is the proper SD card. while several size ( memory) cards may fit the port the player may only recognise a 2 or 3 gig card.
Posted on Dec 30, 2008
  • 12 Answers
SOURCE: how to sink micro sd card with player
You should probably just copy the mp3 files directly from their source folder over to the micro sd. To do this, put the micro sd into some type of adapter that will allow the computer to read/write to it. There are usb sticks that do this and there are SD adapters you put the micro into so you can use a media reader/writer with it. Once you have the card seen by the computer, just drag and drop your MP3's into the drive letter corresponding to the memory card. After that is done, put it back into the player and turn it on. I should find all your songs and make them available to you.
Posted on Mar 13, 2009
e-Guru
  • 3917 Answers
SOURCE: SD card reader not recognizing card
the original file (apparently version 2.0) is here:
http://64.233.161.104/search?q=cache:2288as3q0skJ:www.asus.it/support/download/selectftp.aspx%3Fl1_id%3D3%26l2_id%3D45%26l3_id%3D0%26m_id%3D1%26f_name%3DCardReader_050118.zip~zaqwedc+CardReader_050118.zip&hl=en
the updated driver (version 2.3) is located here:
http://support.asus.com/download/download.aspx?modelname=V6V&SLanguage=de-de
scroll down to where you see RICOH card reader driver
or more specifically this link here:
http://dlsvr03.asus.com/pub/ASUS/nb/V6V/CardReader_XP_2K_050808.zip
even though the site is primarily in german, all the component names are in english, go figure. So it would seem that the asus comp manufacturer are a little more forthcoming than dell in this particular instance. for example, nowhere on my component sheet does it say that RICOH is the manufacturer for the card reader, that's something i got from you guys on the forums
anyway, after installing this driver and rebooting my comp, card reader immediately recognized both MMC and SD media. unfortunately, it was only able to access the mmc card, and i'll be shipping my comp off to dell for whatever motherboard replacement they're willing to give me (which i don't mind, so long as it works when it comes back to me) but i thought these links might be helpful for others who are having the same problem.
Posted on Mar 19, 2009
  • 207 Answers
SOURCE: sd card jammed in sd card slot
This may sound bad, but I promise it isn't. Have you tried removing the SD card with a small pair of needle nose pliers or even some twizzers? It sounds like the spring mechanism failed, so your only solution now is to pull it straight out, a little force and it should come right out. There are no pins to bend on an SD card.
Posted on Apr 21, 2009
Why won't the SD card fit into the player?
Are trying to fit a standard SD card in the unit? This model only accepts the smaller Micro SD card.
Dec 05, 2015 | Eclipse Supra Fit 8GB* Video MP3 Player
Where can I find an SD card for this device? The card slot doesn't accommodate the standard SD card...
Does it use the "mini SD" cards? My phone has a mini, and my DP03 uses standard cards. However I have noticed some mini cards have an adapter, that they fit into, before they're inserted into a device. Try calling or visiting the web site of the manufacturer of your device. Hopefully they can help you, even if the unit you bought haz been discontinued. That's all I've got.
Jul 31, 2015 | GPX Audio Players & Recorders
How do i put my sd card in media player
Upside down? Which media player do you have?
Feb 15, 2018 | Sumvision Cyclone Micro 3 Media Player
What size sd card can the rd1028a use?
Check the width of the slot for the SD card.
Most digital cameras use the standard SD card and the width of the SD card is 24 mm.
The mini SD card is 20 mm wide
May 20, 2012 | RCA Lyra RD1028 MP3 Player
Trying to add storage space unable to add music with new mlcro sdhc 8g memory card. mp3 player says music wont fit.
The Sansa e-series works with microSD cards. While microSDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use microSD cards, 2GB and smaller.
Oct 20, 2010 | SanDisk Sansa e260 MP3 Player
Doesn't recognize the memory card - it is an sd 4 gig micro card
The Sansa e-series works with microSD cards. Your 4GB card is actually a microSDHC card. While it will fit into the slot, it won't work. You need to use microSD cards, 2GB and smaller.
Oct 01, 2010 | SanDisk Sansa e250 MP3 Player
SD card does not seem to fit in the SD card slot
Is the SD card a mini type or a standard SD card?
The standard SD card is 24mm wide X 32mm long.
If it is a mini SD card you need to purchase a mini SD to standard SD adapter, then you will be able to insert it in your Compaq.
Aug 13, 2009 | HP Compaq nc6230 Notebook
Dec 30, 2008 | Creative Labs Zen Digital Media Player
Additional memeory
You might be running into a problem with the new card being a SDHC (Secure Digital High Capacity) card and not just a SD (Secure Digital) card. I have had similar problems with SDHC cards when I put then in older products that have regular SD slots (Photosmart Printer). The cards will still fit into the slots, however the method as to which they are read and written to is different which causes the problem. So, maybe try updating computer hardware drivers or mp3 firmware from the Sansa website. Also, if you can, exchange the 4gb SDHC for a 4gb SD card, this could be a pain in the ****, but this solution should fix your problem definately. Hope some of this helped.
Aug 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
