Question about Honeywell HCM-300T QuietCare Advanced UV Tower Humidifier
Honeywell hcm-310t / hcm-315t no humidity control
Humidity control (electronic) will not shut off...fan runs as long as unit is on. (model hcm-310t/hcm-315t)
5 Suggested Answers
SOURCE: humidity not going up
I have a similar problem with mine too. I am interested to see if anyone can diagnose this problem
Posted on Nov 30, 2007
  • 123 Answers
SOURCE: Are filters still available?
You are looking for replacement filter HAC-504. (which is the filter for the 500 series)
You can order them from Homedepot.com
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=100035531&langId=-1&catalogId=10053&ci_sku=100035531&ci_src=14110944&cm_mmc=1hd.com2froogle-_-product_feed-_-D27X-_-100035531
Hope this helps.
Good Luck.
Posted on Apr 18, 2008
SOURCE: where is on/off switch HCM-305T-CST
There is a 0 setting on the fan speed setting knob ...
Posted on Jan 05, 2009
  • 114 Answers
SOURCE: tank is broken on Honeywell HCM-560 humidifier.
you type in on the internet. www.appliancefactory.com
in the search bar type in your model number. it might take a minute to load but you will have 3 pictures that come up. click on any of them and scroll down alittle until you see water tanks. you can order them there.. or if youdon't want to go that route you can always try local hardware stores to see if they have it as well.
Posted on Aug 21, 2009
No humidity
remove and clean the filter then re-install it the air is being blocked
Dec 03, 2013 | Honeywell QuietCare HCM-630 Humidifier
Humidistat problems
The ability of the humidifier to maintain a given moisture content in the air is far more difficult than a heat or cooling unit to heat or cool the air.
Moisture vapor has far more energy to seek dryer air, than tempered air. So the moisture seeks and finds dryer air quickly, whether it be through stair and door ways, or through cracks and seams in walls and doors/windows, or through non vapor barrier surfaces.
The only way the unit would be able to achieve a humidity level as stated, is for the unit to be placed in a vapor-tite room that has a minimal of leakage.
You could put more humidifiers in the space, or more and larger humidifiers in the space, to try and overcome the vapor moving to other areas of the space. But unless you have a fairly vaportite space, it is unlikely the unit is under capacity, and the only way to test what capacity is needed is to take humidity measurements.
Reply back with any questions you may have.
Feb 03, 2009 | Honeywell HCM-300T Humidifier
Honeywell 6013i new machine will light up...
Unplug the machine and take both the water jugs off. Take the motor unit off and flip it over. Plug it into an outlet and press down the small silver contact at the bottom of the motor. When you press this down, a connection is made and the motor should turn on (Don't worry about being electrocuted, this is perfectly safe). If the motor turns on and runs at various fan speeds, you know it's not an issue with the main unit.
When looking at the base, on the left side you'll notice a plastic piece sticking up that's held down with a plastic shroud and 2 screws. This is you water level sensor. When the water level raises up, this also rises and hits the silver contact on the bottom of the motor. Make sure this isn't binding up(I suggest you clean it) I had the same issue with my HMC-6012i, lights were on at the indicated humidity level but the motor would never run. Take the unit apart, clean it out and follow my instructions. It should fire up (Mine is running right now :) )
Dec 22, 2008 | Honeywell QuietCare HCM-6013i Humidifier
Where is on/off switch HCM-305T-CST
Dec 20, 2008 | Honeywell : Cool Moisture Humidifier...
Fan is running but humidity is not changing
Q: My unit has been running for several hours. I hear the fan spinning, but I do not notice the water level in the tank decreasing.
A:
First, check the filter to ensure it is wet. If the pad appears dry, remove it from the Base and gently rinse under cool water. Reposition wet filter in the Base. You may also want to note the current moisture level in your home. If the humidity level is over 60% the unit will not put out much moisture
as your air is already saturated.
UV bulb and filter are user replacement items
see manual from my other post
Owners manual LINK
Comment by Soulvisitor, posted on Jan 20, 2008 You should notice moisture on the widows in the room after unit has run for awile, this unit carries a 3 year warranty. More info coming...
Comment by Soulvisitor, posted on Jan 20, 2008 see this
4b54ac1.jpg Comment by Soulvisitor, posted on Jan 20, 2008 If water level in tank is dropping and fan runs then I'd say it is working.
OK?
Comment by Soulvisitor, posted on Jan 20, 2008 Q: I hear the fan turning, but I don’t see any mist. Is my humidifier operating properly?
A:
Dry air is pulled through the system and a fan disperses invisible, moisture balanced air. There is no
“mist” emitted. When operating normally you will feel only cool air coming from the unit. Monitor the
water level in your Tank/ Base. If you notice a decrease in the Water Tank over 24 hours then the unit
is operating normally.
Dec 02, 2007 | Honeywell HCM-300T Humidifier
Humidity not going up
Nov 30, 2007 | Honeywell HE360A1027 Whole House...
Honeywell HCM-300T QuietCare Advanced UV Tower Humidifier Logo
Top Honeywell Humidifiers Experts
Dennis
jdthefixer
Bill Long
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
