Question about Broan-NuTone N-9194NT Wall Heater Heater
Nutone wall heater won't turn on
No heat or fan
3 Suggested Answers
  • 95 Answers
SOURCE: Noisy, smelly fan in nutone heater
You should probably replace the heater motor. All the parts should still be available for you fan and it should only take a few minutes to change out.
Posted on Feb 13, 2009
  • 234 Answers
SOURCE: NuTone 9093 Heat-A-Ventlite: Ventilation not working
My guess it will be the motor.That would be the first thing I would do is replace it.
Posted on Mar 14, 2009
Have a nutone 765hl-a heater blows but no heat
If the temperature control is turned up for heat but it is not heating, it is most likely a bad heating element or temperature control. Most heaters are not repairable.
Feb 19, 2015 | Dryers
My bathroom heater shuts off after it's on for less than a minute. After a 10 minute wait, a click can be heard and it can be restarted. But only for another 45 seconds
The click sound is the thermostat. It closed and the allows power to the fan heater. The thermostat is faulty and won't allow you to select a higher heat setting.
Jan 19, 2012 | Broan-NuTone Dryers
The Heater does not heat, the fan blows cold air
Check the heater to see if it's a 120V or 240V. If it's a 240, make sure there is 240 volts at the supply before going any further. If supply voltage is not the problem, it's probably the heating element OR a thermal overload. Take off the cover and see if there is one or more reset button(s) inside. Try pressing the resets. If all else fails, turn off power and use a multimeter to test for continuity across the heating element.
Feb 26, 2011 | Broan-NuTone N-9192NT Wall Heater Heater
I need a heating elament for my Braun model qtx100HL-A ceiling fan heater. I took it out and it is a 6260 eichen 120 v / 1425 watt
My Nutone Model 765HL uses the same heater; I tried the Broan-Nutone website but they were out of stock. Finally found it at Central Vacuum Stores for $35. Here's the direct link: http://www.centralvacuumstores.com/nutone/Broan-Nutone-Heater-Elements/QTXN-Series.php
Hope this helps!
Sep 06, 2010 | Broan-NuTone Heating & Cooling
NUTONE HEATER PROBLEM
contact nutone. the problem is that the sensor that shuts off the unit to prevent overheating is too sensitive or faulty. nutone website seems geared towards selling their product so you may have to call them direct at 1-888-336-6157. this is customer support. good luck.6-6157
Mar 03, 2010 | Broan-NuTone N-668RP Combination Light Fan...
Can 2- 220 wall heaters be run off the same breaker
all depends on the wattage of the heaters. add up the wattage of the heaters divide that answer by 220 and that will give you your amperage draw, then you must size your wire, breaker and outlet accordingly. you can only load a braker to 80 percent of its amperage by the CEC.
Oct 14, 2009 | Broan-NuTone Nutone White Fan-Forced Wall...
Heater doesn't work
You can purchase heating elements for this fan that will solve the problem. This is a fairly new fan model so I would recommend calling Nutone because this model has a three year warranty. They may send you the part you need for free.
Jan 28, 2009 | Broan-NuTone QTXN110HL Fan
Dec 07, 2008 | Broan-NuTone Wall Heater
Low air flow
most fan forced wall heaters do not move a lot of air. check the cfm rating on the heater. the fan sucks in air from the bottom and forces it up to the top where the element is. broan and nutone have good air flow.
Oct 23, 2007 | Fahrenheat FFH1615 Heater
Heating & Cooling Logo
Top Broan-NuTone Heating & Cooling Experts
Colin Stickland
Colin Stickland
brasseng
Level 1 Expert
Paul Carew
Are you a Broan-NuTone Heating and Cooling Expert? Answer questions, earn points and help others
