Question about Exercise & Fitness
How does the incline work on an accusmart treadmill
  • 43 Answers
SOURCE: treadmill not working properly. Incline keeps slipping.
there is a plastic spacer at the rack area on the incline mtr- this white plastic spacer has broken, only recourse u have is to unplug the white wire on incline mtr, and never have a incline, or replace incline mtr when you find out how much the mtr is you might want to walk with out incline- if you was in my area, I have them cheaper
Posted on Jan 08, 2010
SOURCE: don't have a manual for my Weslo Cadence 2300
yes it is a battery thing, you have to pry gently up and the box will pop off there are 3 buttons in holes that hold it down. there is a short wire connecting to its back side, make sure you orient it correctly when replacing... the unit takes a 9 volt battery, you will see the place for it when you turn over the box.
Posted on Feb 20, 2010
  • 6 Answers
SOURCE: Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
Posted on Mar 25, 2010
bwinton
  • 83 Answers
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Posted on Apr 29, 2010
maxtreadmill
  • 832 Answers
SOURCE: no manual for a weslo cadence 2300 accusmart
go to iconservie.com click on manual input this infoWESLO THEN M# (WL23001)
Posted on Jun 13, 2010
Incline does not work but incline motor runs for 3 to5 seconds proform415ct
if the motor tries to work but incline does not go up something is jammed on the treadmill or the incline motor is bad
Oct 17, 2014 | Proform 415 CT - Treadmills
Accusmart treadmill
see the video and lube the rollers bearing front+back too. Test the drive belt motor, and see if there are loose or faulty, and repair + or replace.
God bless you
Oct 31, 2013 | Exercise & Fitness
I have a older sears accusmart crosswalk duel motion proform model# 831.297303 12ov,60hz,12a : serial#E40156459. i just need to know how to adjust the incline to go up!
The instructions are in your owners manual. The manual is available at
http://www.iconservice.com/index.html
Under the motor cover you will find a tech sheet. It will give you the instructions to do a calibration of the incline.
On most of the Icon units sold by Sears, the incline calibration is simple. Start the machine, press the incline up button. Remove the safety key.
The machine should move to max incline then back to minimum.
You may want try try it twice..
If it all works well. the incline will work correctly, if not you may need the incline sensor replaced. Unfortunately, you cannot order the sensor separately, you will have to order the motor.
Dec 23, 2010 | Sears Exercise & Fitness
Apr 28, 2010 | Life Fitness 9000 Next Generation...
I don't have a manual for my Weslo Cadence 2300 treadmill. The accusmart monitor doesn't work. Is it just a battery thing? How do I get in to change it?
The accusmart monitor lifts off the console by placing your fingers in the front. You should be able to then pull the unit off of the console. It is only held on by three snaps. The battery is accessed on the back of it.
Jan 21, 2010 | Weslo Exercise & Fitness
Will my ifit treadmill card work in an incline
Technically, the Incline Trainer and the treadmill are two different type of machines. The incline trainer raises much higher so the card that is designed for the treadmill will not work on the incline trainer unfortunately.
Nov 29, 2009 | Proform Quick Burn Pro Treadmill with 12...
Exercise & Fitness Logo
49 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
