Question about GE Spacemaker JVM1640SJ Microwave Oven
The surface lights on my GE Spacemaker microwave model JVM1650WB008 won't turn off. I have to remove the bulbs.
The surface lights on my GE spacemaker microwave (model JVM1650WB008) won't turn off using the surface lights button on the control panel. When I put bulbs in the sockets, they are on. I have to remove the bulbs to get them to turn off.
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Microwave Surface Lights
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit. It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line. We regularly repair these nationwide for $32.50. Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Feb 22, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Spacemaker microwave surface lights
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 16, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
MicrowaveSvc
  • 9098 Answers
SOURCE: Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
Replace the burned-out
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
Connect electrical power
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
Posted on May 30, 2010
heatman101
  • 43501 Answers
SOURCE: GE Spacemaker Microwave #JVM1650WB008 is not heating.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on May 14, 2011
Changed the light bulbs in my ge jvm315 and know the surface light will not turn off ?
This sounds like the control board also called a smart board in some models has to be replaced.
May 02, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Relace bulbs ge spacemaker model JVM164OCj02 light that illuminates cooking surface of stove
That model would be JVM1640CJ02.
That is covered on page 33 of your owner's manual.
If for some reason you don't still have yours, you can download it here.
Always be sure you unplug power before you remove or install bulbs in a microwave.
Otherwise you may need circuit board repair.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Surface Light Bulb burned out where can I purchase new one. Model ge #JVM230BL001 Spacemaker
most hardware stores/home centers carry them,you will need to unplug the unit and you should be able to access the lamp and unscrew it from inside the cooking chamber near the top of the cavity,you may need to remove a screw holding the cover first
Jun 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Cooktop Light/
Night Light
bulb with a 40-watt
incandescent bulb
plug.
the cover.
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
plug.
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
heatman101
Mar 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I believe the inline fuse is blown - where is it
my microwave will not heat food turn table is not moving and showning red smybols
Jan 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Surface Light Bulbs GE XL1800
Dont waste time blaming the wife. It does not pay. LOL
Call GE customer care. Give them the model and they can 1. Tell you what bulbs to use, 2. Ship you the bulbs or, 3. Send you another owners manual which I hope you will keep in a safe place.
Ray
Nov 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
Feb 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Spacemaker oven, Model JVM240
That would almost certainly be a problem on the control circuit board. If the bulbs happen to short / blow out or if they are removed or installed while the microwave is still plugged in, there is often an arc which causes damage to the board. We repair regularly these boards for such problems for $32.50 nationwide.
Dec 23, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
