Question about Maestro Fan/light Dimmer Ma-lfqhw-wh Fan-light Dimmer
I installed a maestro fan/light switch. Fan and lights get power and are working but the switch doesnt control them
5 Suggested Answers
badenhop
  • 44 Answers
SOURCE: controller (s) not working
Someone used the pull chain on both units. Whenever you install a remote or wall-mounted dimmer, it's always best to cut the chains short (after setting the fan to high) to prevent someone who doesn't know any better from using them.
Download the installation sheets here:
http://www.lutron.com/cms400/PageBuyNow.aspx?id=16977&mn=1815
Posted on May 15, 2009
  • 152 Answers
SOURCE: Lustro Maestro MA-LFQHW-WH Fan/Light Dimmer
something is messed up for sure... two solutions.... disconnect outlet and cap wires.. or open up both boxes and see where / how they they wired the outlet into the fan/ light control and disconnect it there and then pick up power for the outlet from the black /white wires BEFORE the dimmer control
Posted on Dec 06, 2009
SOURCE: ok i installed the Maestro IR on a switch that
Lutron Maestro IR shows several model numbers:
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro+IR%C2%AE+dimmer
You posted under MIR600 single pole digital fade dimmer for incandescent and halogen.
Installation manual:
http://www.lutron.com/TechnicalDocumentLibrary/030864b.pdf
If this is not your dimmer, then add a comment with exact model number so I can read that manual and look for trouble spots.
The manual does not say 'Fan'
It appears this dimmer is for incandescent and Halogen lights.
Manual gives Lutron 24hr/7day tech support number 1-800-523-9466
If you do not want to add a comment for more free assistance, and do not want to call Lutron, then take advantage of fixya phone service.
Expert will walk you through the problem for a price.
Posted on Dec 25, 2010
SOURCE: The LED indicators on my Lutron Maestro
1) If this installation was working before, the Maestro has a small pull-out circuit breaker that lets you reset the device. This is called the FASS Front Accessible Service Switch, located at bottom of dimmer where it meets cover plate.
Open sample Lutron Maestro dimmer manual to see FASS illustration
http://www.lutron.com/TechnicalDocumentLibrary/0301106A.pdf
2) If this is new installation, then double-check your wiring and check that load matches dimmer capacity: 600 watt incandescent or halogen, which apparently excludes CFLs.
Some electronic devices have shortened lifespan on circuits that are not clean. Use circuit analyzer on nearby outlet that is on same breaker to see if line has interference.
3) Lutron has customer service numbers:
1.888.LUTRON1 (588.7661)
1-800-523-9466
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 03, 2011
We just installed and the fan works but not the lights what could it be?
Double check your wiring. If the fan came with the light kit already installed there should be two power supply wires protruding from the top of the canopy. One is for the fan (usually black) and the other is for the light(usually blue.) If you have only one wall switch to control both the fan and light, both of those wires should be connected to the black power wire from your ceiling. If you have two wall switches, one for the fan and one for the light, you should have two power wires coming from your ceiling (usually red and black.) Put the fan wire on one and the light wire on the other. If the light kit came seperately and was attached tho the fan, double-check those connections. Often the small stranded wires will pull out from under the wire nuts. Same for the wires at the top of the fan. Hope this helped in some way.
May 01, 2011 | Hunter Ceiling Fan Light Switch Control
Ok i installed the Maestro IR on a switch that runs a celing fan with a light on it. i turned the power back on in the room and the light was flickering and the fan was unresponsive. please help!!
Dec 25, 2010 | Maestro Lutron MIR-600 IR Satin Color...
I have a weird problem, the fan remote will only work if the light is turned on; I cannot turn on the fan without having the light on - very frustrating when you want to sleep.
Has this just started happening or has it been going on since the fan/light was set up? If there are two wall switches, one controlling the fan and one controlling the lights and they have recently been installed, seems like the fan is getting its power from the light switch. Please tell me if there are two wall switches controlling the fan and lights and we can go from there.
Sep 19, 2010 | Hunter 20537 / 20538 The Vista Iron...
Hampton bay ceiling fan stopped lights work
you can test the light switch by temporarily hooking up the light bulb to where the fan normally goes ....the bulb will only work on the highest speed setting but can prove if the switch is bad or not . turn power off before woking in there ... if you know someone with a volt meter then they could quickly test the switch for you .. they can also test the motor for continuity .. .. most of the time the trouble is simply bad connections inside the wire nuts ... like insulation not skinned properly or wire not in the wire nut properly ..you can remove and inspect each connection (power off of course) ... sometimes there is a seperate power line for the fan and light ... so they can be independently controlled externally ... thats not needed when the pull chains are the only off on method ...
Apr 15, 2010 | Hampton Bay 52 In. White Redington...
I am trying to install a 42" ceiling suspended fan .. just making sure the blue(1) and black(2) wires go together and then the green goes to the bare ground wire coming from the box.
If you are not using a seperate switch to control the fan the blue and black go together and the white goes to white and the green goes to green. The blue wire is the fan power wire and the black is the light power wire if you are just using the switch on the fan to control the fan speed then the above configuration is the way it should be wired.
Jan 19, 2010 | Aloha Housewares (93645) Ceiling Fan
Aug 19, 2009 | Maestro Fan/light Dimmer Ma-lfqhw-wh...
Controller (s) not working
May 15, 2009 | Maestro Fan/light Dimmer Ma-lfqhw-wh...
I have just installed the Lutron Maestro® 600 Watt Single Pole Dimmer, White in my master bedroom. The outlet is connected to a ceiling fan. Every time I turn the fan off with the light on, the light will...
YOu need to make sure that the maestro you installed is designed for use with electric motors. CHeck out this page on the lutron site... http://www.lutron.com/CMS400/page.aspx?id=16955&mn=1797. THese are the dimmers you can use with a fan. If it is in the same box the magnetic interference can cause the types of reactions you are mentioning.
If this is not the problem you need more info-- is the light part of the fan, is there a separate wire for fan motor and light? what type of switch is controlling the light (assuming the maestro dimmer is controlling the fan motor etc...
Dec 27, 2008 | Electrical Supplies
Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
Sep 07, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Maestro Fan/light Dimmer Ma-lfqhw-wh Fan-light Dimmer Logo
50 people viewed this question
Top Maestro Electrical Supplies Experts
Craig Butler
Craig Butler
jdthefixer
Steve
Are you a Maestro Electrical Supply Expert? Answer questions, earn points and help others
