Question about Whirlpool Washing Machines
Whirlpool Washer LXR9445JQ1 agitator not moving
I know its the Agitator Directional Cogs Part Number: PS388034 that are bad but how and the heck do i get the agitator off? its nothing like the ones i see in the videos, the top just don't pop off.
  • 277 Answers
SOURCE: "dog ears"
hi go step by step and you'll do great http://www.american-appliance.com/service_pages/wp_dd_wash/dddogreplacement.htm minor changes are possible good luck
Posted on Mar 29, 2006
  • 185 Answers
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Posted on Mar 25, 2008
  • 958 Answers
SOURCE: remove agitator on a whirlpool ultimate care II washer
have you look at the center of the agitator? after you remove the dispenser.
there i s a bolt there that you have to remove before pulling the agitator at the top.
tnx 4 using fixya,
drcool
Posted on Oct 25, 2008
  • 240 Answers
SOURCE: INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Posted on Apr 28, 2009
  • 4336 Answers
SOURCE: I have a Whirlpool washer
There are tiny "dogs" that need to be replaced. this is a result of overloading and not enough water. The pieces are under 10 bucks and not very hard to install, but tricky. Special tools not needed. They are called agitator pawls, I think.
Posted on Oct 25, 2010
How do I remove the agitator from my Kenmore Washer model number 110.24962300 to clean under it as clothes are coming out with flakes of dirt and soap-scum pieces etc. on them?
Follow these detailed step-by-step instructions to help you locate and replace your Kenmore worn agitator cogs:
  1. Before you begin this or any other repair, disconnect the power supply to your washing machine. Either unplug the unit from the wall outlet, trip the appropriate switch in your fuse panel, or remove the correct fuse from your home's fuse box.
  2. Raise the lid of your washing machine, and if your model uses a fabric softener dispenser, remove it from the top of the agitator by pulling it straight up and off.
  3. Pry off the agitator's cap (if there is one) by wedging a small flat head screwdriver into the slot between the agitator and the cap.
  4. Reach into the agitator top and pull up on the barrier cap and its seal (also called a gasket) to remove them.
  5. Use a socket wrench with an extension or a nut driver to remove the stud and the seal that hold the agitator top to the shaft of the agitator base.
  6. Remove the agitator top by pulling it up off the agitator base. Turn the agitator top over, enabling the cam and the worn directional cogs to slide out. Examine the cam for wear, it also may need replacing.
  7. Attach each of the new directional cogs to the cam. The small round piece at the base of each 'ear' is fitted into one of the cam's four slots. Your model may or may not make use of a black plastic agitator cam bearing. This cam bearing is used to help hold the cogs in place. If your model uses one, make sure you put it back on during the reassembly process.
  8. Carefully insert the cam and new directional cogs into the agitator top the same way they came out. Place the agitator top over the agitator base. There are tabs on the top of the agitator base that line up with, and fit into, the slots of the cam.
  9. If the cogs fall out of place during re-assembly, you will have to take the cam out of the agitator top again and re-insert the cogs.
  10. Push down on the cam until its slots and the base's tabs snap together.
  11. Insert the stud and seal into the shaft and use your wrench or nut driver to tighten.
  12. Make sure the black rubber gasket (seal) is situated properly in the groove of the barrier cap. Then push the barrier cap and seal down into the agitator past the holes.
  13. Replace the agitator's cap or fabric dispenser, whichever your model uses.
  14. Close the lid of your washing machine. Reconnect the power supply and test the machine to make sure it is working properly.
That should do the job for You. Hope this was helpful
Jan 14, 2011 | Washing Machines
Agitator won't spin. Only swivels back and forth when I apply direct pressure down on the center of agitator.
This a very common concern and an easy and cheap fix the agitator cogs are worn out you can order the parts online part number wpl285751 or just 285751 about $4.00 (agaitor directional cogs) or dog ears. or a complete repair kit #285746 about $14.00 I would go with the kit. With parts in hand pop of the fabric softener dispenser then you will see an agitator cap with a pair of pliers pull up and remove the cap,now you will see one bolt remove this bolt and you will be able to remove the top part of the agitator replace you worn parts and reinstall and you will be agitating like new,,,Sounds like a lot I know but its really a 10 minute job Good Luck
Sep 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Wtw6300sw1 agitator moves clockwise no counterclockise mov
This sounds like the dogs need replaced in the agitator. It's relatively easy and inexpensive to do.
Feb 11, 2010 | Whirlpool LSR5132PQ Top Load Washer
Washer won't spin
pull the fab soft dispenser out and pry off the cap that sits on top of agitator looking down inside there you'll see 4 pieces called agitator directional cogs(dog ears) they are worn and need replaced
Apr 06, 2009 | Kenmore 22422 Top Load Washer
AGITOTOR COGS ARE SHOT NEED TO PEPLACE " HOW!"
you can find avideo on you tube, search whirpool washer repair, but youll need to remove the agitaptr. 7/16 screw down the center shaft of agitator, then remove the agitator and split into 2 parts to reveal the agitaotr dogs they simoly slip back into place, part number 80040 in case you havent ordered them yet
Feb 27, 2009 | Whirlpool Washing Machines
Agitator not working properly
if the agitator barely moves, sounds as if yo have a bad set of agitator dogs, part number 80040. if you removeth agitaotr,(7/16 screw) down the center ofthe shaft. yo can removeth efabric softener dispensor by hitting with the palm of hand. after removing the agitator, it can be split in half to reveal hte "agitator dogs" easy repair problalbby about $20 and 30 min tops
Feb 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator gear is stripped
just place both feet on the agitator as it sits on the floor and lift up on the top half. there are plastic tabs on the bottom half that hold the two pieces together. you will need to remove the 2 tabs before putting the 2 pieces together. the bolt that you screw the agitator down with will hold the 2 pieces together. Joe
Dec 03, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Top load Whirlpool washing machine
Many Whirlpool built 'direct drive' washers use a 2 piece agitator. There are cogs called 'dogs' or 'dog ears' and a cam between the two halves of the agitator which can wear leading to a clicking/ticking sound and reduced movement of the top agitator section during the wash cycle leading to poor cleaning results. In most cases these worn parts can be replaced without much cost or difficulty. If you have this style of washer this should help.
Nov 02, 2007 | Washing Machines
"dog ears"
Mar 29, 2006 | Kenmore 24642 Top Load Washer
Washing Machines Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
