Question about Fuji PrintPix NC-1000 Thermal Printer
White vertical line on the print
When I print a picture I find white vertical line on this and I don't know why.can you help me
Have you tried calibrating the print head? Turn off the printer and the controller. Turn the printer on. Once the process light turns off, hold down the exec button and press the left arrow. "Please wait" is shown on the screen, and after a while it starts making noises and the screen changes to "calibrating". This is supposed to solve that problem. It didn't for me, but it's a start.
Posted on May 29, 2009
Vertical lines through Polaroid z2300 printed pictures
i have the same issue, my best guess is that because there equally spaced there is something wrong with a cog, i can hear a faint click that is in sync with the lines. i'm going to investagate more so will hopefully i'll have a definative answer soon
Apr 15, 2013 | Polaroid Z2300 Instant Print 10mp Digital...
Horzontal white lines cut through print and picture copies. When doing head allignment the horozontal bars all have a white gap, 1 through 7. Epson Stylus CX5400
You don't need to do head alignment, because it is for vertical banding in printout. Vertical banding can be minimized by disabling high speed option without doing head alignment. If your printout have horizontal white lines, do check nozzle and head cleaning, or you can minimize white lines by printing in best quality (photo).
Oct 21, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Picture has white horizonal line accross it
You have a vertical collapse. Not sure if its worth fixing because i don't know what type of set it is or how old. But vertical is not usually expensive to fix. Possibly just replace vertical ic
Apr 22, 2009 | Televison & Video
White vertical line in image printing
how can we take all fax sent and received print from hp 3050 printer.
Apr 01, 2009 | Epson Aculaser C1100 Printer
While printing photos my printer has white vertical lines
Sounds like you need to re-align the print cartridge . The reason the text comes out ok is probably because it is only using the black cartridge for text. The color cartridge is the one that's out of alignment. You may have some sort of Cannon utility running in the task bar that will allow you to easily allign the print cartridges. If not, go to the main "Printers and Faxes" window, RIGHT-click on the printer and select "Properties". You should be able to find a button in the properties that's labeled something like re-align print cartridges. It will print out a series of test pages and ask you to select the set of lines that looks the straightest and type it in. It's a good idea to do this every time you replace a cartrige. Hope this helps, If I was able to FixYa, please remember to rate me. Thanks.
Feb 22, 2009 | Canon MultiPASS F50 All-In-One InkJet...
White vertical lines on printed page
change the k black drum... its the only solution trust me
thanks
Nov 19, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
27"tv sharp analog
Good day.
Refering to to mr walts inquiry and if it is, maybe you are having some issues in your vertical circuitry. It may be loose that it needs to be resoldered and other filter capacitors within the vertical section.
chris
Mar 22, 2008 | Sharp 27C-240 27" TV
Vertical lines
1. Took out the ink carts and cleaned the copper contacts of both the ink carts.
2. Clean the copper contacts on the ink carts slot in the printer and then insert the ink carts in the printer and then print out the page.
Dec 11, 2007 | Epson Stylus C60 InkJet Printer
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Fuji PrintPix NC-1000 Thermal Printer Logo
122 people viewed this question
Top Fuji Office Equipment & Supplies Experts
billconfused
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
