Question about Vacuums
Hoover S3755 WindTunnel Bagless Canister Vacuum brush not spinning
    New Friend:
  • 51 Answers
The belt might be streched or broken,also you could have dirt in the bearings on each end of the brush bar. either one of those will cause it not to turn. You will have to remove the brush bar to check that is does not have debris in it. you cant tell from just looking at it still in the vacume.
Posted on Jan 06, 2013
4 Suggested Answers
  • 126 Answers
SOURCE: hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Posted on Jan 20, 2008
ThinkVacuums
  • 144 Answers
SOURCE: need help with Hoover S3765-040 WindTunnel
The belt could be stretched and that could be causing the slip. Or you could have the wrong belt if you've replaced it recently
Posted on Sep 04, 2009
Vac Belts
  • 701 Answers
SOURCE: Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Posted on Dec 23, 2009
Testimonial: "Replaced the belts-- works GREAT!!! Thanks"
Power head won't work when brushes turned off
The power head motor's only purpose is to operate the brush, so that's normal.
Nov 29, 2010 | Hoover S3755 WindTunnel Bagless Canister...
Do i need to let the filter dry before using my hoover bagless hepa vacuum?
Yes, make sure it is completely dry. Other wise, very fine dirt will be much more difficult to remove.
Nov 28, 2010 | Hoover S3755 WindTunnel Bagless Canister...
The suction is quite poor, also definite burning smell after normal use. we only have about 3 years would it be the engine
I would check the drive belts for the beater brush and make sure the beater brush itself is free to move in the holders. Clean the beater brush of all debris and add a bit of WD40 on the two ends between the brush and the holders.
I do not charge for my advice. : )
Paul
Sep 18, 2010 | Hoover S3755 WindTunnel Bagless Canister...
Wiring diagram s3755 hoover
Today I shortened my hose by 4" to get around a tear problem. You can use an Ohm meter to find the right 4 wires. When looking from the top of the canister with the hose heading to your left, the wires should be:
White (furthest connector away from you)
Black - to the switch
Red
Blue
With the Red and Blue going to the speed con trol curcuit board.
Aug 05, 2009 | Hoover S3755 WindTunnel Bagless Canister...
The belt keeps on slipping off causing the brushes to stop
Over time the belt stretches and gets to big to stay put all of the time. Get a new Hoover belt and install it. That will solve your problem
Jun 16, 2009 | Hoover S3755 WindTunnel Bagless Canister...
Hoover Model S3755 Parts List Needed
Go to hoover.com and look up a local Hoover store. Give the a call and ask the to mail of fax you a schematic. They should be pretty helpful.
Jan 07, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
