Question about Dell Inspiron 6000 Notebook
Hi! I have two computers; my desktop will stay connected with no problems, but my laptop will only stay connected for about 20 minutes at a time. What can I do to keep my laptop connected?
    Problem Solver:
  • 8 Answers
Hgh
Posted on Jan 20, 2009
  • Vbikash Jan 20, 2009
    Yes it could be a weak wireless connection. However it also depends on what type of wireless card you use. It also depends on the BSS band, bluetooth colaboration, channel set etc. Check for all this
Does this problem occur regardless of the network you're on with your Laptop? If you're only concerned with one network you should check the desktop to see if it is 'wired' (connected via Ethernet) or not. I suspect the problem is merely a weak wireless connection.
Hi computer will not stay on at all ... before this power would last for 20 mins or so then shut down , no problem with over heating or not charging , any ideas many thanks jan
Hi there it appears if the lights turn off on the front of the laptop and its not warm the the charge/power management chip is going bad and must be replaced I'm having the same problem it might also be ur charger as well
Jan 18, 2011 | Toshiba Sattelite® Pro A200 PC Desktop
I have a HP Media Center PC m1264n desktop.I can turn it on and 1 minute or maybe 5 to 10 minutes into it,it will just shut down,but the power led light on the front of the PC stays on.I reboot it and it...
Is it going to sleep or is it actually shutting down? Do you have to push the power button to turn it back on? Just a thought - if you have Windows 7, go to Start, Control Panel, then System and Security. Now check 'Change when the computer sleeps' under Power Options. Under Edit Plan Settings, what do you have for 'Put the computer to sleep'. Does '20 minutes' show up in the box? Open it and change it to 'Never' and then Save changes. If this didn't help you,maybe someone else can.
Sep 04, 2010 | HP Media Center m1264n - 3.0Ghz 1024MB...
My power cord does not stay charging while plugged in. Normally I hear the beeping as it conects and disconnects, up to 20 times a minute. Do I have a bad power cord? Is the best result just to purcharse a...
If it keeps connecting and disconnecting, it could be either the power adapter or the motherboard, but chances are it's the power adapter (and that's the cheaper solution too). You can usually get a new power adapter for $15 or $20, and that should take care of your problem.
Jun 01, 2010 | Gateway NV5215u Notebook
I've got a Toshiba laptop. I connect to the Internet with several different browsers and have no trouble cruizin the net for anywhere from 5 to 20 minutes. After a time, however, I can no longer go to...
If you are connecting thru a ethernet cable then your ethernet is not working properly. While if you are connecting thru WiFi then the WiFi is not working properly. A cheaper option to get over this WIFi problem would be to use a WiFi dongle on the laptop rather then get the WIFi repaired which would be very expensive.
Nov 08, 2009 | Computers & Internet
Laptop shuts down at random times it sometime shut dowm within 5 minutes i use or can stay on allday but now it shuts down within like 20 minutes of use.please help
I THINK ANY VIRUS MAY BE IN YOUR SYSTEM. PLEASE FULL SCAN YOUR COMPUTER THROUGH A GOOD ANTIVIRUS. IF PROBLEM REMAINS SAME THEN YOU HAVE TO CHOOSE FORMAT WINDOW AND THEN REINSTALL WINDOW.
Sep 30, 2009 | Sony VAIO VGN-AR630E Notebook
I have a Systemax Venture computer that is 3 years old. Just developed a problem. Turn the computer on and after 20 to 30 seconds the computer shut down. What is wrong???
Hi there.
Remove all power to the desktop, remove the side panel, power the machine up and check that CPU fan is working, if it is turn the computer back off, get a clean, dry paintbrush and gently clean the fan blades and the metal heat sync behind the fan of dust, then restart the PC to see how long it stays on for. If this time it stays on it was overheating.
Good luck and thanks for using Fixya!!!
Feb 23, 2009 | Systemax Venture PC Desktop
Internet
Hi i am Naren. You want to brow an your laptop
Oct 29, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Problem with a HP Laptop. When switched on, the screen stays black and after about a minute, the computer restarts itself (screen remains black). It just continues doing this. After a few days, the...
If you are a technician, please take it to the service center. This may be a fault because of failing power supply section in your laptop/ faulty, loose RAM.
Aug 17, 2008 | Computers & Internet
R40 think pad laptop fliking
Right click on the desktop and go to the properties option.Click on the Screen Saver Tab and will find Power option . Click on it and check the power schemes6112293.jpg
Jun 19, 2008 | IBM ThinkPad R40 2897 Notebook
Dell Inspiron 6000 Notebook Logo
54 people viewed this question
Alun Cox
