Question about Canon imageCLASS MF4450 Multifunction Laser Printer, Copy/Fax/Print
Canon mf4450 keeps paper jamming
Jams right at the cartridge -- Ichanged the cartride,but it didn't help
5 Suggested Answers
CordellNJ
  • 21 Answers
SOURCE: Rec . paper jam
This means your rollers are either dirty or damaged. The same thing happened to my Lexmark printer and they told me to clean the rollers. Nothing happened it still was messed up so they just sent me a new one...
Posted on Dec 13, 2007
SOURCE: 'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Posted on Mar 04, 2008
marsrover
  • 682 Answers
SOURCE: Canon B820
please confirm that no foregin object droped inside like (stapler-pins)--confirm that paper jam switch in good condition and it is lever not broken and can move in free motion.-chek for small pieces of torn paper and clean the paper path.
Posted on Mar 20, 2008
SOURCE: "Clear paper jam" error, but there is no jam!
Thanks, tried all the maintenance options including cleaning the rollers. What I have found worked very well was to bin the printer and purchase an HP model!
Posted on Apr 06, 2008
Canon printer says paper is jammed. there is NO paper in printer
Hi,I suggest that you do a complete maintenance check on you're printer by going into you're control panel, click on scanners and printers. Right click on you're printer and go to properties. There should be an option to do a maintenance check. Clean nozzles, head and do an alignment test. Once this has been completed print a test page and hope this works for youRegardsMichelle
Mar 07, 2012 | Canon PIXMA Office Equipment & Supplies
Paper jam. Sheet printed but didn't pass through the rollers
  • Remove the paper tray completely by pulling it out towards you.
  • Now pull the jammed/stuck paper out gently.
  • If you cannot remove the paper by the above procedures,open the printers front cover to access the cartridges assembly.
  • Pull the cartridges assembly gently and slowly.This will come out together with the jammed paper.
  • If jam not cleared,open the back cover and pull the tab outwards to access the fuser unit.Remove the stuck papers here.
  • Hope this helps.Thanks!
Oct 31, 2011 | Brother HL-2040 Laser Printer
Canon pc745 not copying. error symbol 8zig zag line. there is no paper jam and just loaded brand new toner. please help
Hi steven640,
That symbol you are getting is for a paper jam. The figure 8 represents the rollers and the zig zag is the crumpled paper. Since you have already checked the machine for any possible paper jam the next thing you can do is to reset the printer. Here's how:
1. Turn the printer OFF, when it is on, by suddenly and sharply unplugging it from the power source.
2. Also unplug it from the computer!
3. Leave it that way for 10 minutes.
4. Plug it back in.
5. Turn it on if it didn't turn itself on. Wait for it to initialize.
6. Try printing again.
Hope this helps.
Thank you for using FixYa.
Sep 05, 2011 | Office Equipment & Supplies
PIXMA 450...Keep getting paper jam message and I can't see any paper bits anywhere. Trying to open the machine from the back to look inside. Have removed the 4 screws on the back and still can't remove...
Hi
The paper jammed can be found in the paper tray, remove the paper at the paper tray and inspect the roller for small pieces of paper jammed.
The paper can be found in the ink cartridge compartment, open the cartridge door and remove the ink cartridges, look for posibble paper jammer. Also once remove, check also the cartridge carrier if does not stuck up or jammed (cause this might me the problem). Turn off your printer and then move the cartridge head using your hand moving to the from right to left side and from left side to right side for 2-3 times. Move it gently.
Paper can be found in the rear access door if it is accessible. Inspect some paper jammed there.
Please let me know if you need more help
Mar 10, 2011 | Canon Pixma MP450 All-In-One InkJet...
My Canon ip2600 keeps getting jammed. It takes
Lol!!! I was having the same exact problem--- looked in it, didn't see a thing, opened it, still didn't see a thing! I turned it over-- and sure enough, a pen fell out!! lol
Jul 21, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Canon PC735 copier, paper jam light keeps coming on but there isnt any paper or anything blocking the machine. Tried resetting but nothing has worked. What can I do?
My canon copier pc735 says we have a paper jam- but it does not. We just replaced the cartridge and it wont work. I had them send me a new cartridge, but its the same thing- paper jam. Help!
Oct 10, 2009 | Office Equipment & Supplies
Canon mp130 ink cartridge jammed
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Sep 03, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Jammed at far right (error message ##345)
hi
I don't know if you have the same problem as me but my printer kept saying cartridge jammed so I opened it up and moved the cartride head gently to the left and got a flash light there is a little peice of metal on the base where the cartridges sit you have to make sure it is cliked back in and now mine works again.
I hoe this helps
Sep 20, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Canon PC-795
The blinking light with the squiggle symbol is the display for a paper jam. Not sure a service manual will help in this situation other than to be a guide as to where the paper sensors are located. There are usually 3 or 4 paper sensors located in Canon PC copiers. The first sensor will be located between the paper pick up assy and the vertical rollers*(*which are located behind the door on the right hand side used for clearing jams). The second sensor is located under the toner cartridge just before the registration rollers. The third sensor (if present)is located at the entrance of the fuser assy (some models of Canon copiers have omitted this sensor)The last sensor is located at the exit of the fuser assy. I would suggest that you remove the cassette, verify that a piece of paper has not been partially fed or ripped in the pick up assy. With cassette out of machine, open right hand door & verify that there is no jam and check that the flag or arm of the sensor moves freely. Remove the cartridge from machine and again verify there is no jam and the registration sensor arm moves freely. If there is a sensor in front of the fuser assy, verify that it also moves freely. Finally, check for a jam and sensor movement at the exit/fuser. After checking all sensors, unplug the machine and plug back in. (Do this without the cassette & cartridge installed but with all the covers closed) This should give you an install cartridge & cassette message. Install cartridge first. This should give you the install cassette message. Install cassette. If you still get a jam signal when plugging the machine in without the cartridge or cassette, the most likely cause is a blown sensor.(rare, but I have seen it.)If this happens you would then need the service manual to disassemble & repair. I'll keep an eye out for your reply! Good Luck!!!
Jun 06, 2007 | Canon PC-795 Copier
Canon imageCLASS MF4450 Multifunction Laser Printer, Copy/Fax/Print Logo
630 people viewed this question
old marine
old marine
