Question about DKNY Watches
Ny8187 broken wristband
I need to replace the wristband of my DKNY watch ny8187. Where can I orther it?
  • 29 Answers
SOURCE: Dkny watch- repair, need extra links
I suggest calling DKNY customer service @ 1-800-231-0884 This is their return or repair department they should be able to help with links for your watch.
Posted on Mar 12, 2008
VOTIT
  • 2071 Answers
SOURCE: Replacement battery for DKNY NY1050
I found a "battery" website that had some suggestions that should be typical of any snap back case watch.
http://www.online-batteries.co.uk/whichb...
specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment.
The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even.
Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it.
Hope this may help you;
DON'T FORGET TO RATE:
Posted on Sep 06, 2008
escapement
  • 2334 Answers
SOURCE: replace the back of a dkny watch after replacing the battery,
For closing your caseback you need the man with very strong hands first, but it might not work as some casebacks can be closed using special tools only.
Before you visit the watchmaker, try this: first of all open your bracelet by taking out spring lug. This will make more space at the back. Then take watch caseback and check for groove in it. Align that groove with stem (pin going into watch movement) and deepen grooved caseback side as it should be. Then without turning caseback apply great pressure with both hands to the watch(from caseback and dial sides). If hands are strong enough, caseback should snap on into place.
In case if it doesn't work, find a piece of thick leather (wide mens belt will do) and place it on completely flat surface (table top). Place the watch face down on that leather, adjust caseback groove with stem again and try to press caseback down with both hands, only this time using your weight.
If all mentioned above doesn't work- you have to go to see watchmaker.
Good luck.
Arthur
Posted on Dec 17, 2008
dmbgo
  • 58 Answers
SOURCE: How to replace the rubber wristband of a luminox watch
If you have a new wristband, there is a spring loaded lug where the band joins the watch, use a sharp knife or jeweler's screwdriver to slide the lug from the watch
Posted on Jun 22, 2009
SOURCE: where can I get a replacement watch strap for DKNY
http://watchretail.co.uk
http://www.bablas.co.uk
try these...good luck!
Posted on Oct 05, 2009
Where I can get watcband for replace?
You should be able to find a nice wristband for your watch on ebay. If you want to replace with the original you might need to contact Guess directly, however ebay will have more then a few guess wristbands.
Feb 06, 2013 | Guess Sport Leather Strap W16002L1 4 Watch...
Hi. Can You replace a Crystal for DKNY ladys watch model NY-4609 Thank You.
It is probably replaceable. Try to locate a watch repair shop or and jeweler who repairs watches. If they don't have one, then contact DKNY directly.
Jan 13, 2011 | DKNY 1035 Wrist Watch
Cam i get spare links for dkny clear links watch
yes Dkny will give you free links for your watch if you need them . DKNY watches are made by fossil watch company, you can contact them at this telephone number# 1-800-449-3056 to have watch links sent to you.
Oct 14, 2010 | Watches
BROKEN GLASS
Broken glass can be replaced by watchmaker only. Find your nearest watch repair shop and ask to help. You can find plenty of watch repair shops in your area on internet. Just type in your browser: watch repairs in (your town, city, e.t.c.)
Jan 21, 2010 | DKNY Watches
The link on my dkny watch has broken and I would like it repaired where can I send it
Hi
Thanks for using FixYa. You can get it repired from an authorised DKNY service center or can also get it done from these tech.s--
Watches Repair Link
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 31, 2009 | DKNY Watches
Watches Logo
Top DKNY Watches Experts
Ansel Alberto
Ansel Alberto
richie46
Are you a DKNY Watch Expert? Answer questions, earn points and help others
