Question about Frigidaire FEF366 Electric Kitchen Range
Oven element will not shut off when oven reaches temperature
Oven element burned out, replaced but new element shorted out, now oven element comes on but it will not shut off when oven reaches temperature setting.
  • 2,559 Answers
The infinite switch (control knob) is bad .
Posted on Jan 20, 2009
Electrolux oven (model#EW30IS6CJSB, serial#NF21223301) top element won't turn off.
It would not be element bc it only works when supplied voltage. And obviously it works when supplied voltage. Whatever is sending voltage to the top element that shouldn't be is the issue. Such as control board
Sep 25, 2016 | Electrolux Ovens
Whirlpool oven shuts off - Error Code F2
The "F2" error code for this oven means "one or more keys on the keypad are shorted". The correction is to replace the control panel because keypad does not come separate.
The part is not available but if you call the number of that supplier I'm sure they may find the part for you.
Here is the info.
Nov 09, 2012 | Kitchen Ranges
Bosch built in double oven: had new element fitted to main fan oven, but now oven keeps on getting hotter does not stop heating up when right temp reached.
This type of problem normally can be ascribed to a defective thermostat. Unfortunately there is no test for a thermostat, it has to be replaced to see if the problem has been sorted out.
One thing you can do is remove the thermostat bulb from the oven and place place it in a position where it will not heat up. Place an oven thermometer in the oven. Switch on and see of the temperature climbs above what you wee seeing before. This is a very much hands on test as you have no control over the temperature that the elements can get to. As soon as you see the temperature reach a point above that seen before, shut down immediately.
Mar 27, 2011 | Bosch Ovens
Onece the range selector is turned on the light comes on but soon goes out, if you move the selector a little the light comes back on, this stove was made around 1952. Thank You, Dave
Are you talking about the oven temperature control? When turned on to the selected temperature the oven indicator will light and the element will work. When the oven reaches the desired temperature the power will shut off to the element and the indicator light will go out. When the oven cools slightly the indicator light and the element will again turn on. When it does turn off and you turn the knob slightly to increase the temperature the indicator light and element will come on again as you are asking it to heat to a higher temperature. This is normal oven operation.
Mar 10, 2011 | Kitchen Ranges
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
Zanussi electric oven.
The problem is usually a contactor or relay. The thermostat usually doesn't directly control the elements. Follow the wiring diagram or look at the wires from the thermostat. they usually go to a small box and then to the elements The contacts may sometimes stick or always stick. This part is a lot cheaper than the thermostat. Another problem is a burned out element. (Usually the bake element) This can short to ground and not let it turn off. When the elements are on they should glow evenly all over with no hot spots. Look at the broil element also. It is usually at least part way on during baking.
Jun 27, 2008 | Zanussi ZBF260 Electric Single Oven
Reaching desired temperature
one of your elements has burned out or where your incomming wires hook to the range has come loose ans shorted out check there
May 22, 2008 | KitchenAid KERC507 Electric Kitchen Range
Warming up problem
This has nothing to do with the element. This oven should only be serviced by a qualified technician. If you were one, you would already know the solution. You need to go into diagnostic mode to determine if it is the solid state relay or the cc thermocouple. After resetting the hi-limit more than once, it will also need to be replaced.
Aug 24, 2007 | TurboChef TORNADO Electric Oven
Frigidaire FEF366 Electric Kitchen Range Logo
82 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
