Question about Garden
Carb settings for victa v40 engine - Garden
2 Suggested Answers
shahidkap97
  • 392 Answers
SOURCE: wheres the air filter on a victa v40
see this vide,it says where the air filter is
Posted on Apr 07, 2012
Victa mustang tecumseh just had service done please explain what this means:checked max rpm reset rpm to oem limitsthanks
A gasoline engine is made to rev up only so fast. If it revs or speeds up too fast it will blow up. Each engine has a rpm limit. There are springs and settings on the carb that controls this and you should not have to worry about it if some one has checked it out. They are just making sure your engine will not rev up too high.
Mar 24, 2014 | Tecumseh Garden
V40 4 STROKE VICTA STARS AND STOPS
Change the spark plug or could be wire fault
Jan 05, 2014 | Garden
My accelerator cable on my Victa V40 appears to be looser now so when I pull the cord off choke the revs no longer increase, how do I fix it?
hi.. the thottle cable has round end has poped out of its cam housing(gray plastic) inside the plastic carby... the only way to fix that is to remove the carby, but before you do clean your mower as you will create more issues if dirt/grass gets into the parts you will be working on...also take pictures before you start taking thing off, so you know how to reassemble it, as the carby will need to be taken apart....good luck
Jan 01, 2014 | Briggs & Stratton Garden
How do I adjust the throttle on my V40 Victa lawnmower?
There should be spring where you can adjust near the motor
Jan 01, 2014 | Garden
Victa 2 stroke if I push throttle forward engine cuts out, runs well at low rev.
i would check that the main jet in the carb is clean and if it is check that your exhaust port is not getting pluged with carbon.one thing I would try first is replace spark plug if the plug is bad when the engine goes under load the plug will short out.
Oct 12, 2012 | Garden
Victa lawnmower, model FA001NZ94, has no spark.
pull the top cover from the engine and follow the small wire from the coil and see if the fire melted the wire coating and its grounding out the kill switch wire
Aug 05, 2012 | Garden
Wheres the air filter on a victa v40
Apr 07, 2012 | Garden
My victa statesman lawnmower turns over then dies
first thing to do is take gas tank off and clean it good, remove gas line & blow out. you must remove carb. & give it a good cleaning, blow out all passages, you may need a new carb. kit.
Dec 14, 2009 | Garden
I am after a victa mower 2 stroke repair manual
I have a victa workshop manual covering some of the older models which i would be willing to copy the relevent pagesfor you. or might be able to give you soom tips, what model do you have and can you discribe the carburettor, soom victa's use a very odd carb made of plastic
Nov 21, 2009 | Garden
Volvo V40 heater does not work properly
First check if you have enough coolant in your car. If it's low, it might not reach your system. When the engine is off it should be just under MAX.
Mar 29, 2009 | 2000 Volvo V40
Garden Logo
115 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
