Question about Fedders Q Chassis A6Q10F2A Air Conditioner
AIR CONDITIONER COMPRESSOR WILL NOT KICK ON
I HAVE A 10000 BTY A6Q10F2A. wHEN THE UNIT IS TURNED ON THE COMPRESSOR TRYS TO CYCLE ON BUT DOES NOT
  • elevet Jan 21, 2009
    The A/C does have a capacitor and the unit is 3 years old
  • subzero_hc May 11, 2010
    How old is the a/c?
  • 163 Answers
Hi!!! if you have a run capacitor change it..If it still dont work then you have a bad compressor..good luck.
Posted on Jan 20, 2009
Do I need a new control panel if my compressor kicks off every 2 to 3 minutes?
check the outside unit is clear and has lots of air flow, try cleaning the outside with a garden hose, most likely the compressor is cutting out because it is getting too hot.
Jul 19, 2015 | Heating & Cooling
What causes a window unit air conditioner to run for 5 mins then runs only the fan?
It could be low on freon. or the compressor may be getting stock puling hi amps, and the overload switch is keeping it from kick in inn.
Jun 30, 2012 | Heating & Cooling
The air conditioner makes a loud sound when the ac trys to kick in. When i put it under fan it works fine and makes no noise.
Sounds like your compressor is seized/stuck and the unit needs a new compressor. If this is the case it should make a loud buzzing noise for a while and then click when it stops trying.
Aug 14, 2011 | Amcor Heating & Cooling
The air conditioner is on but is not cooling the fan turns on and all but it dosnt cool
possible causes thermostat stuck open/ compressor not working problems related to compressor may be capicitor or the compressor itself.
Aug 21, 2010 | Fedders Q Chassis A6Q10F2A Air Conditioner
My Central air unit wont cool:When I flip the on/off the compressor trys to start but,then turns back off .Do I need a new condensor(capicator) or is it the compressor? Goodman ck42-IC outer unit
it my kick out on low pressure. low on freon or 410a . over the winter monthr if the service are not tru-blued or sealing compound the systen will leak out
Jun 13, 2010 | Goodman CKL42AR42 Air Conditioner
I have a central air unit. It trys to kick on but won't.
check your compressors capasitor and or the compressor itself if all ok you may have to get a hardstart kit for safty consult your a\c tech near you
May 03, 2010 | Heating & Cooling
Air conditioner fan comes on then surges for compressor and stops
You can check if theres power to the compresor by pulling the wires off it and turn it on with the volt meter at its terminals if there's power the comprresor is either burned out jamed or grounded.
Jul 25, 2009 | Dometic Rooftop RV Air Conditioner
AC/Heatpump units cycle numerous times blowing ambient air.
If the compressor never kicks in, I would check the start capacitor, thermostat and the compressor windings. Most times the start capacitor is defective. Some window air conditioners the fan will run while the compressor stop through the thermostat switch. If the thermostat switch is bad every thing runs except the compressor. Let me know, Thanks, Sea Breeze
Feb 07, 2009 | Dometic Rooftop RV Air Conditioner
Fedders Q Chassis A6Q10F2A Air Conditioner Logo
584 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
