Question about Jack Lalanne Blenders
Need cover/lid for jack lalannes health master 100 blender
Trying to find out where i can get a lid for my jack lalannes health master 100 blender/blender model yd-208
SOURCE: health master 100 jammed gears in blender container
no but figures you dont actually give free help.....its all about the almighty dollar..
Peace
Posted on Nov 12, 2008
  • 6 Answers
SOURCE: Jack La Lanne's Health Master 100
First determine..if it is indeed the motor that is fried. Do this by not using the caraffe. Plug in the motor and run it by itself. If it runs fine without smoking again..It is the caraffe that is defective.
If its the motor you are out of luck completely. Jack Lalanne is out of business.
If it is the caraffe..which I suspect it is not...oil the rim of the bearing that is on the outside of your caraffe ..it surrounds the knurled part that is inserted into the blender...even if you are able to get the motor repaired..get in the habit of oiling the caraffe bearing after each time you use it. If you dont it will fail within months to a year of use
Lalanne had they made in China..and using unsealed bearinga that rust out and the contents of the blender come out!! So I discovere dthat oiling that part each time after use..keeps my blender running smoothly.
You might want to take yoru motor to a small appliance repairman..he might find something simple happened.. like a loose wire connection inside! If he does...you have a simple solution and a motor that works!
Remember to oil the bearing a couple drops each time after use...and if yoru caraffe ever fails you can buy a new one..( Oil that one too!) at Cooking Toys..you can google for the address
gmcgeary@gmail.com
Posted on Feb 27, 2009
  • 6 Answers
SOURCE: Product motor failure
Take your motor to a small appliance repairman. It might be something very simple that failed like a loose wire...then follow my tips below..................
I have been thru the fire about this! I sent my Healthmaster in recd another and it failed also. Almost always..it is the bearing that fails in the caraffe that supports the blade. The bearings that Jack Lalanne had installed in China..were not sealed...so they would allow water to enter corrode and eventually all of your blenders contents would come out thru the bottom! Or another thing that can happen is your blade will freeze up due to corrosion....and become immovable.
Jack Lalanne healthmaster is out of business. I manged to get a refund from Tristar..lalannes distributor..BECAUSE they authorized me sending my belnder back for a new one...and then they cashed my shipping check and then threw out my blender!!!!! I also had to call for weeks till I drove Tristar insane...so they ponied up the dough
So I doubt you can receive any money.
But this is what you CAN do!
1) If your motor functions well..you can buy a new carafe for 45 dollars or so from Cooking toys ( google cooking toys and it should come up)
2) OR if your cheap like me...and your blade doesnt rotate easily due to corrosion and your caraffe isnt leaking much...put a couple drops of oil on the outter rim of the bearing ( That would be located directly on the bottom of the outside of the caraffe..it surrounds the knurled metal part that is inserted in the motor for blending.
My blade was corroded and leaking a tiny bit..I put some olive oil on the bearing and it worked great! I have been able to use my caraffe for a month now...when I expected to have to buy a new one from "Cooking Toys" Which I will do if this one fails.
3) If you buy a new caraffe form cooking toys..my advice? OIL THE BEARING WITH A LITTLE OIL...(any kind of vegetable oil) AFTER EACH TIME YOU USE IT! I SUSPECT IT WILL LAST INDEFINITELY>>>BUT TIME WILL TELL!
  • 6 Answers
SOURCE: I received a Jack La
Take your motor to a small appliance repairman. It might just be a loose wire..inside that needs replaced or re connected then follow my tips below.
Jack Lalanne healthmaster is out of business. I manged to get a refund form Tristar..Lalannes distributor..BECAUSE they authorized me sending my blender back for a new one...and then they cashed my shipping check and then threw out my blender!!!!! I also had to call for weeks till I drove Tristar insane...so they ponied up the dough
My blade was corroded and leaking a tiny bit..I put some olive oil on the bearing and it worked great! I have ben able to use my caraffe for a month now...when I expected to have to buy a new one from "Cooking Toys" Which I will do if this one fails.
  • 5 Answers
SOURCE: I have a Jack Lalanne health master 100 and the
This is a link to the company that is responsible for the Heathmaster 100 http://www.tristarproductsinc.com/about_us/welcome.html
Posted on Apr 16, 2009
My Jack Lalannen health master leaks. Don"t know how to fix it.
You did not specify where the leak is coming from, so I can only guess and my guess is the base. Assemble gasket first, then blade plate and then base retainer. You can tighten the base tighter while the unit is on the motor base. the motor base will let you get it slightly tighter.
Dec 12, 2010 | Jack Lalanne Health Master 100 Blender...
Jack Lalane Health Master 100 Bearing for Blade
We no longer offer the Jack Lalanne Health Master Blender or offer support for it. For Warranty, Service or Parts, Please call the Manufacturer- Tristar at 973-575-5400 ext 129
Jun 24, 2009 | Jack Lalanne Health Master 100 8-Speed...
I blended my instruction and owners manual.
You can get this with google.
Otherwise ask manualfox.com - this is the hazzle-less way to get it.
Apr 08, 2009 | Jack Lalanne Health Master 100 8-Speed...
The gear on bottom of container that ingages motor leaks grease into contents of container.
The company that is responsible for the healthmast 100 is: http://www.tristarproductsinc.com/about_us/welcome.html
Feb 02, 2009 | Jack Lalanne Health Master 100 8-Speed...
Health Master 100 - blade came off
Jack Lalanne is out of the blender business. The bearing that surrounds the Knurled piece that you insert in the motor each time you blend are not "sealed" so consequently water gets in there and causes them to fail.
They only thing you can do...is to buy a new caraffe from Cooking Toys ...google it...
It will cost you 45 bucks plus shipping dont buy any extras!
After you receive it BE SURE to oil ( a couple drops will do)the bearing that surrounds the knurled piece that is inserted into the motor each time you blend. Inthis way the unseale dbearing will remain lubricated and will last you awhile. Mine became frozen and I was able to un freeze it and my bleender works fine now for months! An dI use it 3 times a day! I expect I will have to buy a new caraffe..in the future because of corrosion...that I could have prevented with oil.
Any questions? gmcgeary@gmail.com
Jan 26, 2009 | Jack Lalanne Health Master 100 Blender...
Health master 100 jammed gears in blender container
Peace
Nov 11, 2008 | Jack Lalanne Health Master 100 8-Speed...
Leakage
Send it back to Jack Lalanne with $19.99 and they will send you a new one.
Sep 23, 2008 | Jack Lalanne Health Master 100 8-Speed...
Blenders Logo
Top Jack Lalanne Blenders Experts
eyecam
Ross Keen
Are you a Jack Lalanne Blender Expert? Answer questions, earn points and help others
