Question about Amana ALW480DA Top Load Washer
How to replace a belt on an Amana Washing ALW540raw
4 Suggested Answers
CRTN
  • 716 Answers
SOURCE: replacing belt
Put The Belt On The Motor First Then Put What You Can Get Of The Belt On The Other Pulley And Turn It. It Will Give You The Anchorage Needed To Put The Belt Back In Position. If This Doesn't Help Let Me Know And I Will Further Assist You.
Sincerely,
Michael Scott
Posted on Feb 10, 2009
  • 71 Answers
SOURCE: My Amana washing machine stopped spinning.
moz-screenshot.pngac4805b.gifhere is the image on how to change the belt......it's pretty easy to do as you can see by the diagram.PS2027742 is the part number on the belt.
Posted on Oct 03, 2009
  • 901 Answers
SOURCE: install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
Posted on Apr 06, 2010
Amana washing machine will not spin keeps shuting off
If it's a front loader, check the bearing, they wear out.
Nov 22, 2013 | Amana Washing Machines
I need a detailed diagram for my Amana Washer model #ALW540RAW
The pressure switch sends the signal that tub is full and agitation should begin. As a rule though pressure switches are long lasting parts. Usually the problem is in the tube that goes from the switch to a bulb or box on the side of the outer drum. The hose can become disconnected, for example if machine was recently moved, or even a severely unbalanced load. Sometimes a tiny piece of lint can obstruct the hose from the bulb end.
http://www.appliancepartspros.com/parts-for-amana-alw540raw-palw540raw.html
Hope this helps.
Jan 21, 2013 | Amana Clothes Washer / Washing Machine...
Amana LW8303L2 will not spine
http://www.washerhelp.co.uk/washing-machine-repairs.html
http://www.repairclinic.com/Washing-Machine-Repair-Help
Belt replacement on these is a slightly intimidating job to the uninitiated, but possible.
http://www.american-appliance.com/se...stic-Chart.htm
http://www.applianceaid.com/amana-wash.html#belt
Lots of pictures and help at these sites.
Main thing is use ONLY the factory-authorised replacement belt on these. It is designed to have the right amount of slip/grip to enable your washer to work properly. This is CRITICAL on Amanas.
Apr 14, 2010 | Washing Machines
Install belt on Amana top load washing machine
Apr 05, 2010 | Amana ALW895 Top Load Washer
Tighten the belt on an Amana washer?
The belt should already be pretty tight after wrapping around the barrel and the motor pulley. The belt may be worn and should be inspected and probably replaced.
To prevent similar problems in the future I suggest you be aware of how big of a load you put in the washer.
Mar 13, 2010 | Amana 3.2 cu. ft. Top-Load Washer
I need to replace the belt
You shouldn't have to remove the pump to replace the belt. The motor mount can be loosened and the motor moved so the belt will fit over all pulleys without removing the components.
Loosen motor, move it in, install belt, move motor out to correct belt tension, tighten motor mounts.
May 28, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Replacing belt
Sincerely,
Michael Scott
Feb 10, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Amana ALW480DA Top Load Washer Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
