Question about Kenmore 22422 Top Load Washer
Kenmore Series 70 washing machine whines and low flow on cold H2O
I have a Kenmore Series 70 Heavy Duty top loading washing machine. It's 10+ years old. It recenly started making a loud whining sound when filling with cold water. Cold fills very slowly. Hot fills fine with no noise or flow issue. I've checked the screen filter and removed any debris, but issue still remains. Is there a valve or something that isn't opening correctly?
  • Kenmore Master
  • 8,220 Answers
Yeah you need to replace the water valve. To get to it you need to remove the cabinet on the newer direct drive models, If yours has a rear access panel then you simply pop the top to get to the valve after removing the hoses. Fairly simple job. Here is a good website for direct drive coupling replacement . It shows you how to open the cabinet. http://repair2000.com/coupling.html
GVI 151 is the generic part that fix all belt drive models. Direct drive will need its own little water valve buy hay it ain't but 20 bucks.
For a better explanation post you model number in the comment box and I will research it further for you amigo.
Posted on Jan 21, 2009
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
What year was my kenmore 70 series heavy duty washer made Just bought a house and the washer came with.
it is approximately 10 years old.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 13, 2010 | Kenmore 22422 Top Load Washer
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Kenmore heavy duty series model 82672810 hearing a
i would guess you have something stuck in the pump.
you will need to remove the cabinet and then find the hoses going into the pump. when you remove the hoses, you will find something inside the pump causing the noise.
Feb 23, 2009 | Washing Machines
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore 70 series Agitation and Spin Cycyle clicking
Sounds like you have a broken motor coupler. Not expensive. #13 on the diagram. Part # 285753, dave www.washermd.com
Dec 12, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer machine heavy duty 70 series
most likely a water pressure issue try adj shut off valve off slowly until noise stops if water flow not enough ckd fill screens in back of valve for sediment and trash
Apr 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Dec 30, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
854 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
