Question about Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony Trinitron kv32fs16 picture shrinks
The picture shrinks intermittently, mostly when the tv gets moved or bumped. It goes to the bottom of the screen and shows several different colored horizontal lines which then kind of flicker. After about a minute or two the picture eventually restores to normal. If the side of the TV gets bumped again it restores the normal picture. It seems to be worse of a problem when the back is on the TV and once the TV is on for awhile it turns on and off fine without the problem. All other functions work perfectly.
    President:
  • 3,130 Answers
You have a bad solder connection in the vertical circuit. This will require you to resolder these bad connections before it blows out the vertical output IC or other parts in the circuit. Do this ASAP before you make a small repair into a large one. If you have no solid state printed circuit board experience, please play it safe and take the set into a pro to do this for you. Good Luck
Posted on Jun 28, 2007
SOURCE:
My tv has sound but no picture. The screen is greenish in color.
SONY TRINITRON TV 32 INCH MOD# KV-32FS10 SER# 9006800 PICTURE INTERMITTENTLY BLANKS OUT AND COME RIGHT BACK NEVER LOOSE SOUND.
Feb 07, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hi...I have a problem with my Sony Trinitron 29
the power supply section should be resoldered....must be loose contact..in power section...
Jan 26, 2010 | Sony FD Trinitron WEGA KV-29LS35 29" TV
No picture, has sound
This problem usually lies on the horizontal output transistor, try to check also for shorted diode. you can buy ftom any electronic parts dealer or radio shacks stores
Jul 27, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Want to know if my soney wega trinitron is hd compatible
is hd compatible but your hd will have black bars on top and bottom and shrink your tv to about 19"
Jun 02, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Picture Flickering
The sony tuners have been known to get intermittent, it might be a bad ground where the tuner connects to the main chasis, If the problem is in the tuner itself it will be most difficult to resolve since the connections are so small and compacted together.
Good luck
Apr 19, 2009 | Televison & Video
Sony Trinitron KV-32FS12
i think your tv had a lose contact or crack on board
Oct 18, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron KV32FS16==> Need to push pwr button multiple times
after it fails how many times does the red LED blink? check the board very closely for any cracked solder. and then check the main regulators. also look to see if you have any physically bad capacitors, they might look like they are exploding on the top.
Feb 03, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Picture broken and shrinking
You need to change your vertical IC, along with some capacitors around the vertical IC. Capacitor with value 220UF, 10uf, 470uf and finally 1000uf. Doing this will fix the set. Total cost under $40
Best regards
Circuitcity
Nov 29, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony trinitron KV27V22
Solder any / bad connects horiz,vert and power supply then
try again....................T.
Please rate this solution.........................
Nov 15, 2007 | Sony KV-27V22 TV
Sony FD Trinitron WEGA KV-29LS35 29" TV Logo
156 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
