Question about HP Compaq Presario SR1503wm PC Desktop
Is there any way to add a dvd r+- writer drive to my compaq 1503sw. If so, what should I look for to fit my expansion drive
  • 51 Answers
You can find internal DVD-R+/- about anywhere, Walmart, Best Buy. It just has to have an IDE connection which is very common. You could also look into USB external drives. Average price is around $35.
Posted on Jan 20, 2009
  • 184 Answers
Follow instructions in this link:
How to replace the dvd drive with dvd writer ?
You take the securing screw out, you slide the old unit out gently, you disconnect is cables, you buy a PATA dvd writer like and install it in the opposite way.
Sep 01, 2011 | HP Compaq Evo Notebook N1015v
Can my CD-RW/DVD Rom Drive, model # GCC4320B be replaced with a hp 24x Multiformat DVD/CD Writer, dvd 1270i . I bought this unit today, but the connections don't match up? I truely appreciate your time and...
This model DVD/CD writer is a SATA drive and unless your motherboard has a SATA connector then you have a slight problem. You will need to purchase a SATA controller and install it into your PCI expansion slot, then connect your new DVD/CD drive to this SATA controller. You will also need a SATA adapter power cable converter which plugs into the 4 pin power connector.
Feb 08, 2011 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
Trying to copy some pics onto a cd to get some disc space but my drive wont recognise the cd rw
do you have a cd writer or rom drive is the first thing you have to check, if it's a writer then put the disc in first and it should give you an option to write files to cd accept then follow the the instruction to add your files, assuming your running windows. iif that does'nt work check to see if your discs are + or - it may be your wriiter will only accept one kind
Mar 26, 2010 | Compaq Presario V4000 Notebook PC
I have a Dell Latitude D530 laptop - does it have a DVD writer?
According to your Service Tag, your machine was shipped with an 8X DVD -ROM & 24X CD/RW Combo Drive, so yes you will need to purchase a DVDRW drive. There is a single layer burner that 4.7GB, and a dual layer model for 8.5GB. They can be purchased from Dell directly, or eBay, Amazon etc (same drive fits D630, D830 etc) and there is a rectangular button on the lower right hand side of the drive that you press in, to pull out the existing CDRW, and simply slide the new drive in. You will need a Burning software like Roxio or Nero to burn DVD's onto the new drive.
Jan 02, 2010 | Dell DVD-rom DVD Drive
Dvd writer
I stick with Pioneer at the moment. I've had so much trouble with many other brands, but Pioneer drives seem very good at writing even low quality discs which tends to be an indication of a good drive.
Jan 20, 2009 | HP Compaq Presario SR1503wm PC Desktop
I have a compaq presario SR2150NX and i need to replace the CD drive. What should i buy
The solution is that do not replace the cd drive !!
You could buy a new DVD writer drive which can be very useful.
You can use both "cd drive" and the new "dvd drive" at a time.
New DVD drive comes only for rs.1200/- to 1500/- .(LG,Samsumg or moserbaer).
Yes ! you can operate them normally as usual.
Only call your computer engg. to make connections or the shopman to fit the dvd and cd drive.
Jan 07, 2009 | HP Compaq Presario SR2150NX PC Desktop
Compaq presario dvd writer light blinking, dvd not working
check if power jack working right. Try to change it with other jack. Sometimes the pins inside jack are loose. try to tight them.
May 12, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
Please check and let me know the exact model of your computer. If you have a door in front or on top you should see the exact model number. I want to make sure your system can handel a DVD writer. Are you replacing a cd with a DVD writer or adding a 2nd drive? On all compaqs the the new DVD drive needs to be set to CL(Cable Select ) on the back of the new DVD drive. Also make sure you have the right IDE cable and power.
Jan 05, 2008 | Computers & Internet
Dvd writer problem
If everything works fine except that disk then its the disk its self.
either there is a scratch on the disk or it was a bad burn from the manufacturer.
Nov 03, 2007 | Computers & Internet
Hp 1040i-b light scribe dvd
I am Vikram Kumar Thumu from India-Hyderabad. I have seen your message on the issue. I would like to provide my suggestions on the issue. I working in HP as technical Support, so I am sure that I can tell you best information available for Your PC.
I see that you are using HP Compaq dc7600 Small Form Factor PC , and you are looking for install of new HP dvd1040i-b DVD writer.
Yes, you made a right choice. You can either go for HP dvd1040i-b DVD writer. or HP dvd1040i 20x Super Multiformat DVD Writer. Both DVD's machines are best. They suite and fit in your PC.
For your convienience, you can buy  HP dvd1040i 20x Super Multiformat DVD Writer from below HP link:
If you need any furter assistance you can mail me at:
Oct 27, 2007 | Computers & Internet
HP Compaq Presario SR1503wm PC Desktop Logo
71 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
