Question about Sharp Televison & Video
Sharp remote cx34d2 portable colour tv
I don't have an av button and would like to connect a dvd player is there a way
thanks
jayne britten
SOURCE: Power Outage - now DVD will not play through AV
I am having the same issue with mine. I even set everythign back to factory defaults and it still wil not work. Isn't there any tech support palced to find help? See post by Scriptster. Thanks
Posted on Oct 11, 2006
Benimur
  • 6966 Answers
SOURCE: RE; Remote control TV/AV button doesn't work LXI series
Hi, Based on your post/description: 1. the TV is stuck to A/V; 2. you have two video sources - VHS & DVD (assuming both are external and both have A/V outputs with the VCR also with inputs); 3. you want to use either VHS & DVD, one at a time. You can do it the old fashion way, remove yellow, red, white RCA connectors from DVD and plug them at the outputs of the VHS when you want to use the VCR; or Connect the A/V outputs of the DVD to the inputs of the VCR, connect the outputs of the VCR to the A/V inputs of the LXI TV. Hopes this give you an idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Aug 24, 2007
  • 22 Answers
SOURCE: Can't access AV Channel on Sony KV-C27TD
If the TV has no RCA inputs, then there is no "AV channel" option for it on any remote, just channel selection.
The purpose of a RCA to SCART converter (aka RF modulator) is to convert one of your channels to an A/V input. They operate (standard) on either channel 3 or 4 as selected by a switch on the converter.
If your converter is unpowered, it's entirely possible that the signal coming out is not good enough to overpower your antenna signal. In this case, you may need a powered unit (such as this one http://www.bestbuy.com/site/olspage.jsp?skuId=5806345&productCategoryId=abcat0107025&type=product&tab=7&id=1067388827858#productdetail) which can actively "shut off" the antenna input when signal is received from the auxiliary device.
Posted on Nov 13, 2007
  • 979 Answers
SOURCE: hooking up portable dvd player to sharp aquos tv
Audio and video out from the DVD unit go to the A/V In of the Sharp....Accordianman
Posted on Nov 26, 2007
  • 12 Answers
SOURCE: Connect Philips DVD to Sansung TV
the red and black are the same as the red and white, these are the audio left and right channels. the yellow plug is the video plug. the next thing you have to check is wheather your tv has video 1 and 2 channels
Posted on May 10, 2009
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
I can't connect my portable Philips PET721D/05 to a TV.It has AV jack and when connected all I get on TV is sound from the DVD player.What am I doing wrong?I'm using a cable that fits into AV and has 1...
The yellow connector is for video and the white conector is for mono sound. ( as standard colour codes state) so if you have the correct connections on the tv it should work. alternativly you can buy a "block" that will plug into a scart socket and you can connect the av lead to.
Mar 20, 2010 | Televison & Video
Cant get color picture when playing DVD's
I too had the same problem. On the Vzio there are AV plug ins on the left side (not the back, but the left side). Use these jacks when connecting to the DVD player and choose the AV button on the TV remote. Viola!
May 27, 2009 | Sony Televison & Video
Technically challenged...need DVD to show on TV screen
hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
Jan 01, 2009 | Pioneer DVR-520H DVD Recorder
I have an Onn 15'' LCD TV Model No OLCD1504 and am trying to connect a DVD player that only has an AV out.I have tried connecting it with a Scart to Av lead in all combinations i.e. via freeview box,direct...
Some dvd players do not have the switching line fro your tv to automatically select scart input but you will be able to select via the tv remote if there are no buttons marked av it can be an oblong with an arrow pointing inwards or you may have to select via the source menu on the tv if you have your original handbook it will give a helpline number for Asda.SUPER8.
Jul 31, 2008 | Televison & Video
Setting up DVD/VCR
Depends how you have connected to the TV.
You will need to set your TV to the relevant socket you have connected the DVD/VCR into.
S-Video, Component , composite etc
These will be EXT 1 , EXT 2 or AV 1, AV 2 etc.
Feb 18, 2008 | Philips Magnavox DVD/VCR Dual Player
MPEG4 HDD Player
Connect your HDD Player to your Television (TV) or Monitor using AV Cable; your TV will become a full of AV Entertainment System.It is Capable of Downloading Files from your Computer,HDD Player can be act as your Mobile Hard Disk that Back-up your Important Files .It is Compatible with 2.5" IDE hard disk up to 500GB (not included)
vk1_3.jpg To computer :
Connect your HDD Player to your Computer using the USB2.0 output cable (cable provided); your HDD Player will become your External Hard Disk that will be managed by your computer Window Software ,Back-up your Important Files. But it need additional 2.5" IDE hard disk to work .
To TV or Monitor :
Your TV will become a full of AV Entertainment System after you connect your HDD Player to your Television (TV) or Monitor using AV Cable.Play movies,mp3 and view picture on TV directly,
vk1_2.jpg Specifications:
  • Compatible with 2.5" IDE hard disk up to 500GB (not included)
  • It support NTFS and FAT32 formats
  • AV out to TV directly, VGA out to Monitor
  • When connected to your Computer, Do not connect your Power Supply
  • When connected to TV,it need power supply ( included,and which is compatible with your country)
  • Displays digital photos and movies on a TV, monitor without the use of desktop or laptop
  • Playable programs: MPEG4, Xvid, Divx, DVD,SVCD, VCD, JPEG, MP3,JPEG picture and MP3 song
  • Portable HDD function: USB 2.0 interface, windows management, be convenient for your study work and entertainment
  • Key button and Remote control operation
  • Supports TV type: PAL and NTSC
  • Audio outputs: stereo 2-ch (RCA)
  • Supports OS: Windows 98/98SE/2000/ME/XP
  • Portable design :132 x 80 x 19 mm
  • weight:215g
In the package comes: 2.5'' HDD player,USB cable,AV cables,remote control,manual ,power supply
Jan 29, 2008 | Computers & Internet
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
Can't connect DVD player
Use your TVs remote and select AV usisng the TV/AV button. Most DVD players use the AV Cables to connect to TVs.Yellow Video Out to Video IN of TV, REd and White Audio Left and Right to Audio L and Audio R IN of TV.
May 23, 2007 | GE 27GT622 27" TV
Televison & Video Logo
57 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
