Question about Exercise & Fitness
Proform elliptical works but won't stop beeping
  • 103 Answers
SOURCE: Have proform 850 elliptical, unit jerks at bottom of travel
This is caused by a loose crank arm. The key assembly is loose. (#32 on your parts list) The covers will need to be removed to access this. Be sure the crank arms are realigned against the frame when completing the repair. Good luck, Tim
Posted on Nov 13, 2009
SOURCE: My Proform elliptical is not working
clarification: when I get on the stepper there is not resistance. I'll get to a point when my feet will bascially fall right around....like something is loose or broken
Posted on Feb 10, 2010
maxtreadmill
  • 832 Answers
SOURCE: After replacing batteries on Proform PF800 console stays lit
Pull the batteries out let it reset itself while its doing that check all cable to make the connection are seated firmly then reinstall the batteries, unless the function pad is sending a phantom signal engaging the display to be on continuously,or by pure chance the upper electronics went hay wire
Posted on Apr 11, 2010
Testimonial: "Thank you very much for your advice! Very helpful!!"
ercupa190
  • 12223 Answers
SOURCE: my proform 2605 elliptical the right foot pedal is
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Posted on Nov 30, 2011
ercupa190
  • 12223 Answers
SOURCE: e7sv elliptical just beeps can't set restance
Dear Sir:
Adjust the Reed switch attached is the diagram for adjustin.
2) Change the batteries by new ones, and clean very well the contact batteries.Tight the flexibles cable from keypad and connector.
3) Run the software calibration for easy diagnose and troubleshooting.
4_8_2012_12_54_36_am.gifsincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Posted on Apr 08, 2012
Proform elliptical 825 can't get the display to stop blinking?
If you are not working out on your trainer, the display should flash for a while and than completely stop. But if it continues to flush, please call proform support.
Feb 26, 2014 | Proform Exercise & Fitness
Proform 500 le elliptical
I would suggest that there is a wiring fault or dry joint. you need someone who is tech savvy to check inside the head.
Jan 28, 2014 | Exercise & Fitness
I have a 390 proform Elliptical and it's is locked up. When I get on it, the pedals are tight and I can not move them.
There may be a problem with the belt inside the machine.
It has to be taken apart to assess.
Jul 14, 2013 | Proform 395 E Elliptical
Resistance on elliptical acting weird
1) tight the bolts tension for magnet and clean very well. and proof..if the fail
2) go to test the magnet, use again the magnet from your refrigerator magnet, for attraction and repulsion. If do not pass the TEST replace the magnet in any Hardware such home depot, etc.
God bless you
Aug 27, 2012 | Proform Nordic Track Elliptical Resistance...
Proform 405 CE Elliptical display and Silent Magnetic Resistance control stopped working
1) adjust magnet with the bolt looses with a wrench, tight very well.
2) proof the magnet for attraction or repulsion with the magnet from your refrigerator, if NOT pass the test replace it.
God bless you
Jul 24, 2012 | Exercise & Fitness
Proform elliptical 10 ze won't turn on
Dear Sir:
1) Replace by good batteries new one 2) Clean very well the contact with contact cleaner spray from R.Shack.
2) Turn the flywheel untill passing for the reed switch,and adjust it see the diagram attached, and ready.
ernesto cuadra
Apr 03, 2012 | Exercise & Fitness
I am getting very frustrated, i want a owners manual for a proform elliptical 6.0 ez
Go to website from Proform: www. proform. com
then go customer service , then go to part& manual give you model, serial number and download free you user or owner manual and Ready!
SINCERELY.
e.cuadra
managua, nicaragua. c.a.
Oct 16, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
Apr 09, 2010 | Proform PFTL79807 - 850 W/ Gamefit...
Nov 10, 2009 | Proform PFTL79807 - 850 W/ Gamefit...
Exercise & Fitness Logo
63 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
