Question about Samsung SGH-t329 Cellular Phone
Not able to charge
I plug the charger into my t329 and it will not charge. I've looked at the connection to see if it was miss-aligned but no luck. I also used a different receptacle. Any advice or should I just get a new one? Thanks.
Ha Jan dat smily face verraad je een beetje, (weet ik nog van je golf ballen) gewoon een nieuwe kopen, maar dat heb je waarschijnlijk al gedaan. Groeten Paul
Posted on Jan 23, 2010
My dell laptop isn't charging when plugged in. What should i do?
Dell chargers have a centre pin to allow the laptop to sense that the charger is a genuine Dell one. If the battery is not charging then:
a) Battery is faulty (old and dead)
b) Pin missing on the charger, wire broken or not original Dell device
c) Charging port on the laptop has become loose.
Hope this helps.
Jul 02, 2016 | Dell Inspiron Computers & Internet
Tip
How to revive old Ni.Cad and Ni-Mh batteries.
This is a hit or miss procedure so do it at your own risk. It sometimes happens that your above mentioned batteries go dead and your charger doesnot recognize them and shows an open circuit or similar. to reveive these batteries you will need a 12v Lead acid battery. connect the -ve terminal to the -ve and +ve to the +ve for approx 6-10 secs to each cell individually the cells should be warm to the touch and not hot. At this pint you should connect them to your charger and it should start charging them. most of the time it works but it is not foolproof method.
on Mar 01, 2010 | Radio Communications
Charging instructions
The instructions on how to insert the camera battery and charge in the Inov8 universal charger are available in this youtube video
Inov8 Universal battery charger
The inov8 charger for panasonic battery should be similar to use. You have to align the pins of the battery with the charger terminals and connect the mains plug. If you have the 12v travel kit then connect to the car lighter socket.
Aug 05, 2014 | Inov8 Digital Battery Charger for...
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
Philips 707/05 Portable DVD Player charging issue.
Just go out and get a new charger to replace the one with defective wire/plug.
Aug 31, 2017 | Philips Vacuums
My motorola Blur won't charge, I've tried other chargers and nothing, it will catch a charge for a second and then nothing, now my phone is dead
My Motorola Blur would not charge kept saying Connect Charger. I tried various power connecters including the Original one that came with the phone and the USB to no avail. This morning I took the phone apart and clean it and still would not recognize the charger.
Fix: I lifted up the connector where the charger plugs into on the actual phone and now it is making contact and appears to now be charging my phone.
Sep 15, 2011 | Motorola Mobility CLIQ Cell Phone
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
I have a pride cleberity x...when i plug in the batt. Charger..will not charge...checked all fuze's
Not always the batteries, the chargers are made like garbage, I've gone throught 3 on my power wheelchair. The wheelchair companies will charge you over $300 for new chargers, check EBAY and get one for under $76 they work great and have a warranty
May 10, 2010 | Pride New Mobility Legend 4 Wheel Scooter
My blackberry isn`t charging, i`ve plugged it in and nothings happening, when i plug it into my computer it has a lightning symbol by it but im not sure what it means?
does the phone charge when connected to the computer? The lightning icon means it is connected to power and is charging. Try another charger, it seems like your charger is the problem, not the phone.
Dec 15, 2009 | RIM BlackBerry 7290
Samsung SGH-t329 Cellular Phone Logo
163 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
