Question about Canon PIXMA MP830 All-In-One InkJet Printer
My scanner stopped working yesterday. Tried everything and no luck. Its an MP830 and the printer works fine.
  • 1 more comment
  • pauloreilly Jan 20, 2009
    I think I did. I just checked my device manager and it says the scanner is disabled.I try enabling it then install the driver (all while in device manager) but it then says it's disabled again.
    Right now I am going to try unplugging it, let it rest a few mins then try again. But tell me if there is somethign else to do. I see lots of posts about this problem all over the net.
    No luck. Any more suggestions?
  • xiller8er
    xiller8er May 11, 2010
    Have you Tried uninstalling the software/drivers, and re-installing them again?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,001 Answers
Did you have a storm or lightning? Try unplugging the power cable from the left rear of the machine (not the wall). I have had to do this on several occassions after storms. Good Luck!
Posted on Jan 20, 2009
Canon MP830 Scanning from ADF..paper stops halfway, hangs...
I had been moving some furniture and I think I inadvertently knocked a usb cable loose. I also had it going to a hub that was possibly not working. when I made sure everything was hooked up correctly and directly, it was working fine again. I hope this helps someone.
Jun 25, 2009 | Canon Office Equipment & Supplies
SmarThru Office can't see scanner (nor can word)
Windows is using Window's default scan driver, so it's working only within Windows scan wizard feature. You will need to install the Scan Driver separately to work with SmarThru and other software. The Scan Driver is available at Samsung website.
Apr 16, 2009 | HP PSC 1350 All-In-One Thermal Printer
CANON PIXMA MP830 Error Msg: Scanner not working correctly.
the error message: "Scanner is not operating correctly." The scanner is definitely unlocked.
Nov 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp 830 getting error 5000
Canon site if the link does not work just go to canon.com -> support-> select Multifinction --> Inkjet --> Pixma MP830
Then type in - error code 5000 - (Leave off the " - "
Select #3 - ERROR LCD: Error code (5xxx through 9xxx) appears on the display -
1. Press ON/OFF switch to reset the multifunction device
2. Press Stop/Reset and ON/OFF to reset the printer
3. Removing paper jams MP800R / MP830 / MP530
4. The MP830 may require repair
5. Unlock the scanner lock switch (MP800R / MP830)
The links above detail each instruction. If they do not work here then got directly to the Canon Site.
Basically at one point there was a paper jam so clear it and then reset the machine.
Worked for me. Good luck to you :)
Oct 24, 2008 | Office Equipment & Supplies
Canon MP830 wont scan
you have to use other programs such as photoshop to use the scanner
Mar 28, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Scanner
I couldn't get the MP830 scanner USB interface to work on initial installation. Canon was unable to help, other than to say that the USB 2.0 had to be native (i.e., had to be on the motherboard, and not an addon board). London Drugs computer dept (from whom I bought the printer) suggested that re-installation of the operating system (WinXP) might help. Bingo - it worked!
Jan 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon pixma mp830 will not scan
I am experiencing the same problem, from the equipment id does not scan
Oct 31, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Scanner has stopped working
When I had the cable that came with the printer connected to the scanner, and the cable that came with the scanner connected to the printer, the scanner didn't work.
Changing the cables changed everything.
Oct 15, 2007 | Canon CanoScan LiDE 70 Flatbed Scanner
Dell 810 not printing
Dear chibihamster, It seems that there is some loose connection in your printer. If you have a little knowledge in hardware, please open your printer carefully, check all the connected cable specially the printer head connector. The best way is that disconnect the printer head cable and reconnect it again. Do not do anything in your scanner circuit area, otherwise it will create you more problems. If this doesn't solve your problem, please contact the manufacturer. GOOD LUCK!!
Aug 31, 2007 | Dell 810 All-In-One InkJet Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
128 people viewed this question
old marine
old marine
