Question about Exercise & Fitness
Bodytrain treadmill has a error coming on screen e02 dont know what it is
Computer screen is on when press start counts down then nothing happens error e02 comes on screen
magic seadog
  • 38 Answers
SOURCE: E02 error
E02 indicates that the mode switch did not rotate into the next position after 6 seconds during unloading attempt. This problem can occur for several different reasons, but almost always requires mechanism repair and retiming, a real pro job. Good luck, magic seadog
Posted on Aug 12, 2007
Coldcut
  • 1554 Answers
SOURCE: Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
Posted on May 12, 2008
SOURCE: Carl lewis treadmill
I also have this problem. I rang Carl Lewis Support and they said to check the connections on the circuit board (Located in the floor panel next to the motor). If the treadmill had recently been moved something may have been dislodged. I checked mine and found a few loose wires and plugged them fully back in but this didn't help my treadmill. I'm awaiting a response from an e-mail i sent them now.
Posted on Jul 26, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: my lg intellowave microwave will not work
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can download many LG service manuals here, but strangely, they do not have part numbers in them.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
If you don't find your model's service manual or need more help, feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 30, 2009
SOURCE: cadence weslo 340 cs treadmill wont engage treadmill
If the transformer does not produce a "hum" the power is either not reaching the rectifiers or the rectifiers have died . Not likely if the machine was running last time prior to being put away. Try physically advancing the tread/belt to set the motor to a different contact starting point since corrosion (ambient humidity) may have dulled the motor contacts(brushes).
Posted on Dec 31, 2009
Error message E02 on Reebok ZR8 Threadmill - please help if possible
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 01, 2016 | Exercise & Fitness
Why does my t210 treadmill stop and then come up error e02?
Hi this is due to the treadmill's belt speed loss.
This happens if the motor is faulty or if the belt is stopped suddenly due to too much weight on it or misuse.
I would have the motor checked if I were you.
Feb 08, 2016 | Exercise & Fitness
Can you advise please
reset the machine make this: God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Nov 28, 2013 | Precor 935 Premium Series Treadmill
How the error e02 on fit king treadmill be repaired
Dear sir,
I am having a treadmill of Fitking model no. W590 it is showing error code e02.
Kindly suggest what to do. I am eagerly waiting for ur response
Rgds
Yash Pal
Jul 15, 2013 | Exercise & Fitness
Lifespan treadmill has a dC-1 code
Reset the error follow the steps. God bless you
    • 1 Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
    • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
Mar 25, 2013 | Lifespan TR800-DT Treadmill Desk
Get an e02 error every time I press start on my hyper extension treadmill
Replace the old battery from display board
2) clean the contacts batteries+adjust the REED swithc see diagram
3) tight the ribbon cables and clean it
4) LUBE the deck belt and rollers bearing
5) Test the motor and see the control motor board see the b.diagram
Mar 05, 2013 | Exercise & Fitness
PLO5 error message on Quinton Clubtrack treadmill
Try to clear the error message. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 2
  • 3
Jan 25, 2013 | Quinton Stairmaster Clubtrack 3.0 GymTough...
Error Code E7
To fix the error you have to put the safety key in start it it and wait for it to say E7. Now press stop and incline( up) together and hold for 20 seconds. Your treadmill will start to incline up. Take out your safety key. You just restarted your treadmill and can now put the safety key back and your problem will be fixed.
Apr 22, 2012 | Exercise & Fitness
HEllo, i get a Unable to Clean error on my mfc-5440cn, i tried to put the power down for about 1hours and back up, still nothing . can you help me ?
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
All I ask is come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 11, 2010 | Brother MFC-5440CN All-In-One InkJet...
Jul 06, 2009 | Exercise & Fitness
Exercise & Fitness Logo
147 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
