Question about Doro Lands Phones
How do I top up the handle plus 334 gsm- - Doro Lands Phones
2 Suggested Answers
  • 89 Answers
SOURCE: puk for doro 334 gsm
ur puk code would be on the box u got r the sim pack when u got the phone r u can get the code by call ur network op and they tell u it
Posted on Jan 15, 2011
Can you replace a Maytag smooth top on a slide in range?
Yes it is replaceable but expensive. Approx $334 plus shipping at sears. The glass top unbolts at the front then lifts off at rear but all the burners must be removed and mounted to the new top.
May 31, 2014 | Maytag MER5775Q Electric Kitchen Range
How do you remove the Metris S wideset faucet handle?
To remove the handle simply rotate the escutcheon counter clockwise and it will unthread from the fixation on top of the counter. Then the handle will lift off as one unit. You can clean them with CLR to clear up water deposits. If you need further instructions feel free to contact me Hansgrohe Tech 1-800-334-0455 press 2 for Technical and ask for David Scarborough. I'll be happy to help.
Apr 08, 2013 | Hansgrohe 31063821 Brushed Nickel Metris S...
Dismantle the handle plug
Most Hansgrohe faucets or handles have a plug in them. This does not come apart but in most cases you simply push the plug into the handle and once you have removed the hendle you can retrieve the plug from inside the handle or on top of the faucet. If you need further help fell free to contact Hansgrohe Tech at 1-800-334-0455 press 2 for Technical.
Apr 05, 2013 | Hansgrohe Plumbing
Hansgrohe 06040620 handle repair
The bell shaped portion of the handle should turn counter clockwise and unscrew from the base. Then the handle will lift off as one unit. If you need more help feel free to contact me Hansgrohe Tech at 1-800-334-0455. Press 2 for Tech and ask for David Scarborough.
Mar 30, 2013 | Plumbing
Leaking tap
This is most likely a cartridge that has worn out and needs to be replaced. Most of the kitchen faucets use cartridge number 92730000. This is available through your local dealer or online dealer. If you need further help feel free to contact me at Hansgrohe 1-800-334-0455. Press 2 for tech and ask for David Scarborough.
Oct 10, 2012 | Hansgrohe Plumbing
Replacement hans grohe 32313001 valves stems for handles
If you need help finding parts or dealers I will be happy to help. Feel free to contact me at Hansgrohe 1-800-334-0455. Press 2 for Tech and ask for David Scarborough.
May 22, 2012 | Hansgrohe Plumbing
How to adjust water pressure
To adjust the pressure on this type of valve you simply rotate the handle counter clockwise from the off position. As you rotate the handle it will increase the volume as you increase the temperature. Feel free to contact me at Hansgrohe. David Scarborough 1-800-334-0455.
May 06, 2012 | Hansgrohe 06358620 Pressure Balance Valve...
Puk for doro 334 gsm
Jan 15, 2011 | Doro Phone Easy
Manual/datasheet for siemens sitop 10A power supply
batteryconector pulled from the pannel, how can i solder it again
Mar 24, 2009 | AT&T Siemens S46 GSM Cellular Phone
Lands Phones Logo
Top Doro Lands Phones Experts
castletech
castletech
Greg Cann
Greg Cann
Gene Tuck
Are you a Doro Lands Phone Expert? Answer questions, earn points and help others
