Question about Exercise & Fitness
My display on my York 3100 elliptical cross trainer comes on but doesn't seem to work
The display comes on, but it doesn't pick up movement so you can track speed or distance?
SOURCE: Schwinn 431 Elliptical doesn't register rpm's, distance, etc.
I have this same problem and called the customer service. The problem is that the rpm sensor is not working. It could be the sensor or something else. They had me check the connections first for the wiring harness at the top and middle and then sent me parts to work on the inside where I have my problem. I am still working on mine because the magnet was installed on the wrong side of the flywheel. Hope you don't have this issue.
Posted on Jan 08, 2011
  • 28 Answers
SOURCE: What is an elliptical trainer?
An elliptical trainer or cross-trainer is a stationaryexercise machine used to simulate stair climbing, walking, or running withoutcausing excessive pressure to the knees.
Posted on Jul 09, 2012
SOURCE: How many calories can I burn on an elliptical trainer machine?
how many calories you burn depends
a) on your weight
b) on the exercise speed
c) on the exercise level
d) as a combination of all factors on your heart rate
For example, I at 80kg usually do about 400 cal in 27 minutes @138 heartrate :-)
Posted on Jul 23, 2012
  • 69 Answers
SOURCE: Are there different types of elliptical trainer or one generic type sold by various manufacturers?
There are in fact three types of elliptical trainers - all categorized by the motor (drive) location. The three types are as follows: rear drive, front drive and center drive.
Posted on Aug 02, 2012
  • 20 Answers
SOURCE: What are the physical benefits to using an elliptical trainer?
There are several physical benefits associated with using an elliptical trainer as part of your workout regime. They include: toning of upper body muscles and joints, less impact on your body, great cardiovascular workout for the whole body, increased muscle control, a decreased risk on injury, improved balance and coordination as well as an improvement in muscle control.
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
User manual for Kettler 07854-000 "Orion" Cross-Trainer Elliptal
Try here
http://toolbox.kettler.net/fileadmin/_kettler_dam_import/SPORT/Dokumente_-_Kataloge/Montage_und_Ersatzteile/Cro(ss)trainer/07854-_Orion_706f-1003.de,en,fr,nl.pdf
Oct 28, 2014 | Exercise & Fitness
Display not working. hasn't been used for over a year, is it the battery
The battery is definitely the #1 culprit in this situation. When you use the machine, you actually help keep the battery charged. When the machine is not in use, it gradually loses its ability to hold a charge.
Video about How to Test Battery
Feb 14, 2014 | Life Fitness 9100 Elliptical Cross Trainer
I fried the labelled R12 resistor beyond identification on the console circuit board of my York 360 HRC elliptical cross trainer. York service is no help. Need schematics on the circuit board or something...
you should be able to get a new R12 resistor at radio shack. be VERY careful when heating the solder up to remove/replace the resistor. Hope this helps!
Nov 16, 2013 | Exercise & Fitness
Need new display
Contact Life Fitness to send it in for repair. Last I checked it is about $500. I do not know of any aftermarket options.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Feb 14, 2013 | Life Fitness x5i Elliptical Cross-Trainer...
Do elliptical trainers have adjustment qualities?
Yes. Most trainers have adjustments for elevation. The elevation feature on an elliptical doesn't make the workout harder; instead it changes the emphasis so that the higher the slant, the more your glutes and hamstrings will be worked out; whereas the lower positions emphasize more on your quads and calves.
Aug 02, 2012 | Exercise & Fitness
In what way is an elliptical trainer different from a treadmill?
Treadmills have a moving belt while elliptical trainers have two foot pedals guiding movement - making it more controlled and safer. Elliptical trainers also have handles, in which the user has the option to move their arms in opposition to their legs to better control movement.
Exercise & Fitness Logo
77 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
