Question about Boating
Where is the choke solenoid for an evinrude 200 hp located. I have a problem with the choke but cannot find where the solenoid is located on the motor to repair
Just need to know where it is so I can check the choke is working properly. It seems the engine is running with the choke stuck on which is making the engine run on reduced power when accelerating.... I have managed to find the fuel pump which apparently looks similar. Can anyone please help on where to find this?
I have a 150 the choke should be in the same place as mine .......when you are standing on the boat looking at the motor it should be on your left side by the carb's..........should be a round black thing with a little red lever on it
Posted on Jan 08, 2013
5 Suggested Answers
centralvalle
  • 386 Answers
SOURCE: engine was flooding out\now fuel primer has to be used to run
recheck float level as well as needle and seat for sticking and or damage, just crack line to bleed air , and eventually it self bleeds anyway... also unless you replaced with new floats check float weight with a float scale to see if floats are saturated or have fuel inside making the heavy and inaccurate ...
Posted on Aug 04, 2009
  • 58 Answers
SOURCE: Evinrude, 15hp 4cycle outboard, 2000 model - starves for gas
hi obviously a fuel fault someware / when motors are winterised the fuel system is usualy emptied, this causes gaskets and diaphrams to dry out and split try it with the tank filler off /replace the diaphram in the carb and i am pretty shure that will solve the problem /nb / as this motor has stood for a time and does not do much work /outboards love work check the water pump impellor and put a spoonful of oil in a full tank of gas hope this helps merlin v12
Posted on Aug 29, 2009
  • 5522 Answers
SOURCE: Evinrude 3.3 does not run proper when the choke is off
It sounds like the manifold vacuum is low. This would mean the engine is getting more air than it needs and can not create the vacuum for fuel draw. When you choke it, the outside air is reduced and the vacuum goes up and more fuel is drawn in enriching the mixture. The raw gas can not atomize without the vacuum. You swing the other way when you dump gas without the choke.
If you can find a vacuum port to attach a vacuum gauge, you turn the airmixture screw until you have the most vacuum(highest) and then turn the mixture screw in until the vacuum just starts to drop. This is the optimum setting. Marine shops also use flow (meter)flaps to balance multiple carbs on a motor like they do on motorcycles.
You could get the timing checked because this will affect vacuum draw too. This site is suppose to have free manuals, but you may have to Browse the internet for other sources.
Let us know how you made out.
Posted on Sep 18, 2009
  • 44436 Answers
SOURCE: 1991 EVINRUDE 25 HP 2CYL 2CYCLE IT RUNS ON BOTTOM
get a spark tester that has 2 leads and test spark .
Posted on Apr 26, 2010
What should the compression be on a 1988 evinrude 185hp outboard?
The compression on your Evinrude outboard should be at least 100 with no more than 10% difference between cylinders. Keep in mind gauges can give very different results. Also, remember the test should be run when the engine is warm!
Hope this helps!
Jun 13, 2016 | Johnson Evinrude Ignition Kit, Digital,...
Why doesn't it accelerate unless I engage the choke?
Scotty, this is usually due to carburetor being dirty(plugged jets) or a vacuum leak.
Apr 16, 2016 | Evinrude / Johnson 135-150-175-200 HP...
Were is the serial no located
On a sticker usually on the left side of mounting bracket
Dec 02, 2015 | Evinrude / Johnson 135-150-175-200 HP...
1996 Evinrude 140hp started but ran only for about 10mins.
try removing the feed pipe off the fuel pump to the carbs and start the engine , put a pipe on the pump into a container and see if its pumping ! ?
Apr 19, 2015 | Evinrude / Johnson 135-150-175-200 HP...
Hi have a 1984 evinrude 35 hp model no E35RLCRR that wont start
There should be two hot wires one from the battery and one from the switch the one from the switch check should be hot when the key is held on the start if it is the starter solenoid is bad
Dec 23, 2014 | Clymer EvinrudeJohnson Outboard Shop...
What year is this evinrude 135 hp boat motor? serial #j0007646
To have the year of your engine, we'll need the engine typenumber, not the serial number...
Sep 08, 2014 | Evinrude / Johnson 135-150-175-200 HP...
Cn ne one tell me the poistion of the choke
On some of these motors you only press the choke buttton while it is cranking. You may have a problem with the power to the choke. You may want to test the choke solenoid by operating the choke button while the ignition is on momentarily. You can then see if all choke flaps move. There may be an adjustment to keep a little gap for air to enter.
Jun 03, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
132 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
