Question about Goodman GMS90703BXA Heater
Furnace wont stay on
I have a 12 yr old Goodman oil furnace that wont stay on. I just replaced the ingnitor and wondering if it needs some type of adjustment. It was operating fine, however until we got oil and my wife decided to run the unit, so I am wondering if sentiment got into the nozzle. The nozzle is new, however I had that replaced by a tech. Is there a guide to show how to access the nozzle to find out if it is dirty.
Understanding it's dangerous I did push the reset several times jamming more oil into the system. The furnace will operate all day, however will not start again automatically once it has cooled down overnight, because we also heat with wood and allow the therm to drop to 60 and generally speaking the wood stove will keep the temp above 60.
  • Nathan Thurman
    Nathan Thurman Jan 20, 2009
    The filter has very little time on it and was changed at an earlier service, however probably has 100 gallons run through it.
    The problem is; the furnace won't come on with out a manual reset. After one reset; It will run long enough to start the blower and then shuts off.
    If I press the reset multiple times it will start, smoke up the house from the burn off and keep going for the rest of the day. It seems once its primed enough it will stay on. Even when it shuts off once it reaches the desired temperature and start back up automatically, however if its left off overnight it goes back to the problem of having to manually restart.
    We have had several techs come out and they have been shady characters, or unreliable. One of which tried to convince us that our furnace needed replacement, but it didn't. The other repair company kept blowing off their appt's. We are hoping to become more knowledgeable, as it seems in our area we get shotty service, or worse.
    Hope this information is helpful and thank you for your reply.
    Nate
  • subzero_hc May 11, 2010
    Did the tech change the oil tank filter by chance?
    Scholar:
    New Friend:
  • 70 Answers
Have you checked to see if oil is coming out of nozzle? you should be able to put a flash light in the axcess hole. Is there sparks going acrosas electroides? Has furnace filters and oil filter been chanded, and furnace been cleaned?
Posted on Jan 20, 2009
New goodman 80% gas furnace leaking condesation down exhaust vent
it could be condensation. or poor seal at roof. probably the seal at roof. also check the larger copper line is it sealed good? if any spot is not this will cause leaking when in cooling mode. maybe dripping from line onto vent.
Jan 28, 2014 | Goodman Manufacturing Goodman 60,000 btu...
Furnace wont run ...thermostat battery went dead i replaced the batteries and still furnace wont run...We recently had a power outage for approximately 12 hours. This furnace is in our garage. we had...
Hello, The first thing you need to check with a multimeter is if you are getting 24 volts between the R AND C terminal on the intergrated control board. If not than the transformer is blown and needs to replaced or the fuse on the control board has blown and will need to be replaced. When check for 24 volts at the R and C terminal make sure the door switch is pushed in, u can just use electrical tape to temporaily hold the switch in. If you are getting 24 volts at R and C and notthing continues to run than the intergrated control board is most likely the cause and must be replaced.
Feb 04, 2011 | Goodman GMS90703BXA Heater
16 yr old heil furnace sometime lights on 1st ignition other times it lights then burners go out right away it might do it 3 or 4 times then it stays lit
The air intake may need to be adjusted or check the gas valve or if it is oil check your cad cell it may not be registering your flame and needs to be replaced that is normally pretty cheap. good luck
Mar 15, 2010 | Cross Furnace Draft Inducer Blower 115...
Furnace lights fan comes on then fan goes off furnace stays light until overtemp takes it out code flashes 4
Have some one hold the bottom door safety switch, turn furnace on wait until heating fan relay clicks, and check at terminal (Heat) & terminal (neutral or where all the white wires are located on the control board) for 115 volts to 120 volts. If voltage is present replace blower motor, if voltage drops out while running then replace control board.Turn power off to furnace, open bottom door and feel blower motor with hand, if motor is real hot replace motor. you can not oil this type of motor, it has to be replaced along with the compacitor. Good luck.
Jan 22, 2010 | Goodman Furnace Draft Inducer Blower ...
Goodman GMP Furnace problem. Original problem is
Good one! Is the flame getting to the flame sensor within the few seconds? Maybe a good cleaning of the burners or flame tray would help. 1.3 ma is enough for the flame rod to tell the board to stay on. Re-do all the ground connections both at the board and furnace cabinet to be safe. Check the polarity of the power going to the furnace. What are the chances the second board is bad?
Jan 15, 2010 | Goodman Heating & Cooling
Pilot light does not stay lit
check that pilot flame is in contact with the thermocouple the small copper cylinder if not properly burning against adjust if flame is good and the therm/coupl is not covered in soot(wipe clean if has build up)thermocouple gone bad replace
Oct 28, 2009 | Goodman GMS90703BXA Heater
Goodman GSK9 (2yrs. old) gas furnace won't run
I don't have the same system, but on mine when I replace anything, I have to reset the system by killing power to it for a few minutes.
I hope yours is the same,
RSMITH972278
Oct 15, 2009 | Heating & Cooling
Code: open upper limit on a 1 yr old Goodman furnace
The sensor over the flame has tripped. It will need to be replaced or check for a disconnected wire.
Oct 11, 2009 | Goodman GDS80904BNA Open Flame Heater
Goodman gas furnace power vent motor and housing replacement
You need to type GOODMAN GAS APPLIANCES into you browser to find you local servicecenter. I must tell you that Goodman only sells to authorized service companies in my experience. So you become EgKraft Company.
Nov 07, 2008 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
323 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
