Question about Home
How to replace a bellavista stylo toilet seat?
I have a bellavista stylo toilet that is fitted to the wall and floor. how do I replace the toilet seat?
heatman101
  • 43501 Answers
SOURCE: CAN'T IDENTIFY THE MODEL OF MY TOILET AND SEAT
Look inside of the tank the number will be stampes into the porcelin of the inside of the tank...
heatman101
Posted on May 28, 2010
Testimonial: "thank you great help Ira Beu"
  • 43 Answers
SOURCE: unable to fit a toilet seat
do you mean a water seat? like where you would install a water line? or a a seat you actually sit on?
Posted on Nov 16, 2008
  • 10865 Answers
SOURCE: elongated toilet doesn't fit where a round toilet was installed
Hi. There are toilets designed to accept a round seat and there are other toilets designed to accept an elongated seat. The primary difference is that the round seat fits a round bowl and the elongated seat fits an elongated bowl.
I recommend that you return the elongated seat and exchange it for a round toilet seat. good luck
Posted on Jan 31, 2009
  • 3600 Answers
SOURCE: How do I replace the toilet seat on a Kohler
I repaied one of these laast week and it had the Plastic nuts in between the webbing on the seat where the lid connects I believe You remove the plastic cap with a knife and use a flat tip screw driver to remove the screws and replace the seat.
Posted on Jun 01, 2010
  • 81 Answers
SOURCE: Installing Washlet toilet seat on Toto toilet
The water supply line on your Aquia toilet was installed before the tank was mounted to the bowl and the tank must be removed to change it.
Posted on Jun 02, 2010
Trying to find a replacement toilet seat for Bellavista Stylo white toilet in Sydney Australia
I had this problem also. Reece Plumbing sell replacement soft close seats, as do Bunnings. Also call Ostar International116 Milperra Road, Revesby NSW 2212 Phone: (02) 9773 3788, to see if they can assist.
Make a cardboard outline of the top of the bowl to match the geometry.
Oct 02, 2015 | Home
Bellavista stylo toilet
Hello.
I live ind 18690 Almunecar, Andalusien, kan you help me with where I can by a new toilet seet.
With Kind regards
Mogens Madsen
Jun 06, 2013 | Home
I'm looking for round buffers that fit below the toilet seat to stop the seat resting on the toilet bowl. The brand is Gala.
Lowes or HD should have that or a specialty shop. Worst case, the mfr. would have that. You can take the plastic caps that cover the bolts that hold down the bowl in place on the floor and secure them to the seat. All you want is it to support the seat. There won't be any sideways pressure on it. It would just slide on the bowl if it did. If the cap is too tall for the seat, then you can grind it down some to level the seat.
Feb 22, 2013 | Home
Our toilet is 127mmsfrom the wall to the centre of the s fitting and most toilets are 140mm, how can we fit a new toilet pleaase, also the water pipe is on the left hand side and toilets i have loked at...
Toilets water pipes can come on either side majority are on the left side when facing toilet.A longer water supply line can be used for the water connection if the toilet has it on the opposite side.A plumbing supply house and some good hardware stores will carry a close rough toilet that can set 50 mms closer to the wall than a standard toilet. Generally toilets are measured from the wall to the center of the drain in the floor which standard is 304.8 mm so a close rough would fit with a drain 254 mms from the wall
Jun 22, 2010 | Plumbing
I have a toilet which is a one peice. The toilet seat has come loose and the bolts have dropped to the floor. I can not fit the seat back as the pieces that i would use to tighten the seat are on the floor...
In no case would you ever have to pull a toilet to get to seat bolts.My guess is if you take the tank lid off and look inside there youll see the bolts . If not you can buy another toilet seat with new bolts or just get the bolts to fit your seat and tighten it down.Forget about the old bolts unless they become a problem with the flushing of the toilet. Hope this helps
Jun 22, 2010 | Home
Jun 02, 2010 | Toto CST414M-51 Aquia Dual Flush Close...
Elongated toilet doesn't fit where a round toilet was installed
Jan 31, 2009 | Kohler - Toilet - One-piece - Gabrielle -...
Unable to fit a toilet seat
Hi neenyc02.
I'm Harvey the Master Plumber.
Your problem is: The cistern to your toilet is behind a wall. and you can't fit a new seat
I'm having trouble visuallising your problem. For the average toilet there are only two sizes, round front and elongated. Compost and other special types are usually made to accept one or the other. If we're talking about a small marine tupe or such it would still install very much the same way. If you could upload some clear pictures of your problem it would help a great deal. In any case you will need access to the bolt holes (top & bottom).
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 26, 2008 | Toto Aquia II Dual Flush Toilet
Home Logo
328 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
