Which compartment does the soap go into and which does bleach go into
SOURCE: can i use the drying
Methinks you could do with a manual- for now and probably later ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
SOURCE: Haier HWD1000 washer/dryer
solved!!!! theres a flaw in the machine, lint builds up in air return area from the back of the machine to the heater, takes about 45 min to fix, take off lid and back pannel, remove weight, remove heater wires and hoses, remove plastic air return area, clean out lint, put back together, the air temp sensor is in the plasic housing in the rear of the plastic housing, the lint blocks air from circulating and triggers warning
