Question about Maytag Performa PAV3200
Maytag performa pav3200 washing mach. very load shrill noise during spin
When the drum is rotating/spinning there is a very loud shrill sound. I would hate to provide a bias, but is sounds like a bearing related issue It is top loading maytag performa Model # pav3200 rev 12 serial # 122864777k . Do you hve a suggestion about what specifiic parts may be required for a fix? Thanks-Mike
    New Friend:
If you just bought it it probably is the shiping pin. it is a large boldt in the back of the front load machines, smaller pin in the side or rear on toploaders. it keeps the drum from spinning in transit. people forget to pull them all the time. especially if you installed it yourself. If that isnt the problem, try leveling it. Newer machines spin much faster than older ones and one tiny bit off level will make it rattle and shake.
Posted on Jan 06, 2013
  • Jeani Jan 06, 2013
    One other thing to try is cleaning the machine. if it is a high effeciency model and you arent using the HE detergents it will build up and cause problems. Noises and partially cleaned clothes will be a big clue. Clean the empty machine with a washer cleaner, sold in most grocery stores. Or just put bleach in it and run 2 cycles. One with bleach and hot water, the next with just cold. water.
SOURCE: Neptune washer load noise.
I do know there is a set of bearings on the drum drive shaft. There is an inner and an outer. Some places mention that these bearings are no longer available. However, I found on ebay a gentlemen who sells these bearing and the seals in a kit for about $80.00. It comes with instructions on how to repair and will save a lot of money. I have done this once already to the same washer, now I am doing it again. If you search on ebay maytag neptune parts you will find his listing for a bearing kit. He also describes the jet engine noise.
Posted on Sep 13, 2008
duby1990
  • 370 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Posted on Nov 18, 2008
  • 85 Answers
SOURCE: LOUD NOISE IN SPIN CYCLE
you have a bad tub seal asm. remove agitator, spin basket and tub asm. remove seal and install new one. good luck
Posted on Dec 16, 2008
TheMobilian
  • 8220 Answers
SOURCE: Very loud noise during spin cycle
Probably a broken strut or support. some call it a shock absorber.
Posted on May 17, 2009
  • 84 Answers
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Posted on Jul 27, 2009
Have a proforma toploader and is making a grinding noise in both wash and spin cycle. it is still draining and doing everything just making the noise.
We have a proforma toploader washing machine and when using the machine in makes a very loud grinding noise during the spin and wash cycle. On occassion it also does not spin the clothing out properly, however the machine is still usable.
Dec 29, 2010 | Maytag Performa PAV3200
Whirring noise on spin cycle
i have had this problem before you need to repace the tub bearing assembly which reqires special tools to do the job and the whole unit needs to be torn apart
Oct 19, 2007 | Maytag Performa PAV2200
My maytag washer stopped working during the wash cycle. it made a clicking noise when it happened.. I pulled off the belt it is still in one piece . when i put the maching in spin with the belt off the...
If you turn the transmission pulley one way it will agitate the other it will get hard raise up to release the brake and then turn the transmission and the inner drum. If you cannot turn the drum then I would check to see if a nail has gone through one of the holes in the bottom of the drum or a piece of clothing has jammed between the top of the drum and the top cap of the outer tub.
Nov 01, 2010 | Maytag Performa PAV3200
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Jul 27, 2009 | Maytag Performa PAV3200
Maytag performa washer grinding noise
Sounds like the water pump is going out on it. The part runs about $80 and should only take about 45 minutes to install.
Jun 25, 2009 | Maytag Performa PAV3200
Washer wont agitate or spin
Sounds like your transmission is going bad. usually they will pop the belt when going out. Probably with a service call and the cost of the transmission, you'd do better heading to sears. Sorry to bear the bad news. Good luck.
Apr 21, 2009 | Maytag Performa PAV3200
Knocking in washer
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
good luck.........
Mar 28, 2009 | Maytag Performa PAV3200
Rattling noise during high speed spin
sounds as if you might have a bad rear bearing, real obnoxious almost painful to listen too kinda sounds. big job, but might have some part warrentee depending on age of unit
Oct 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
67 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
