Question about Rheem Heating & Cooling
The blower on my funace, Rheem RGAA-08EA, will not start. The burner lights but the blower doesn't start
    Novelist:
  • 189 Answers
Possible bad motor and/or bad capacitor and/or bad blower relay.
Posted on Nov 28, 2014
3 Suggested Answers
  • 24 Answers
SOURCE: Rheem gas furnace blower unit not working properly
look at circuit board and follow wires that come from fan motor, if this is a standard motor black is high and it will be going to a prong that says cool, red is low and it will go to heat, you will have a yellow and a blue that are "parked" remove red park it were the blue is and put blue on heat, if this is a variable speed motor you will have to set dip switches via your equipment manual
Posted on Sep 30, 2009
HVAC_Doug
  • 18 Answers
SOURCE: RHEEM OIL FURNACE MODEL ROBD 067 LBEA BLOWER
You will likely need to install an isolation relay in the W circuit from the thermostat. Some thermostats rob a small current through the W circuit to power the thermostat. This small current can be enough to start the fan circuit timer. You can test this by disconnecting W at the furnace and allowing the timer to shut down. If the fan shuts off with the W disconnected you can install a simple relay.
The relay coil will be connected to Common on one side and the W from the thermostat to the other. Then you will run a wire from R on the furnace to the relay and from the N.O. Contacts to the W terminal on the furnace. This will kill that signal that is starting the timer and the W can steal it's power through the coil back to common.
Posted on May 22, 2010
My Rheem rgra will not ignite. There are no trouble lights.
Sound like a pressure switch issue .Take pressure switch hose off and make sure there is no blockage .If no blockage is found then put a jumper on pressure switch and it furnace work then pressure switch is bad .
Also make sure your vent outside is clear
Feb 15, 2018 | Heating & Cooling
Furnace tries to start. Blower fan moves momentarily but doesn't.
May have a start capacitor on fan to get it started. If fan only jerks, it is probably bad. Replace if needed. Be sure to short it out with a rubber handled screwdriver or something to make it spark before removing.
Feb 18, 2013 | Rheem Water Heaters
Rheen PVW50 Hot Water Heater Making Buzzing Noise and Doesn't Light
Why is it always Rheem problems?
Every water heater problem is Rheem.
And Rheem doesn't post any service manuals, like the other two big manufacturers, AO Smith-American, and Bradford White.
Copy following link for troubleshoot by gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Scroll up and find pressure switch heading among links.
You can install gas control valve yourself.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 06, 2012 | Rheem Water Heaters
Blower fan on Rheem RGAC-08EA
ZOOM SPOUT OILER IS YOUR BEST FRIEND HERE, SOME OLDER MOTORS HAVE LITTLE CAPS ON THE END BELLS OF TH MOTOR YOU CAN REMOVE AND DRIP OIL INTO , BUT THOSE ARE RARE MOST ALL NEW MOTORS NEED TO BE TAKEN APART TO OIL. TAKES SOME TIME BUT WELL WORTH IT !! CUZ MOTORS AINT CHEAP ! JAY THE POOL PUMP GUY IN LONGWOOD FL
Feb 02, 2012 | Heating & Cooling
My furnace and blower wont work but my pilot light is lit
It could be a number of things. Relay, transformer, bad motor, you either need a multimeter with a tiny bit of knowledge in order to track the voltage and find where it is stopping or a professional. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 30, 2017 | Heating & Cooling
Pilot will not stay light but will turn on and work properly
When having a problem with pilot and burner, the place to start is troubleshoot section in your manual.
Whirlpool is probably made by Craftmaster which I believe is a Rheem company, and Rheem makes a number of different models.
Some models have specific manuals and others have generic manuals.
Open Rheem water heater page and click on water that matches your water heater. On page that opens, click on tab that says 'specs' and then download manual.
http://www.rheem.com/Products/tank_water_heaters/gas_water_heaters
If none of those water heaters look like yours, open following link to help identify company website and download manual. Craftmaster website does not have instruction manuals.
http://waterheatertimer.org/Water-heater-manufacturers.html
All gas water heaters require periodic maintenance.
Some require yearly maintenance.
The burner parts require cleaning.
http://waterheatertimer.org/images/Clean-burner-300.jpg
http://waterheatertimer.org/images/Clean-burner-250.jpg
http://waterheatertimer.org/How-to-install-gas-water-heater.html
May 01, 2011 | Whirlpool Water Heaters
Water won't get hot, code c2 11
1-866-720-2076
Available between 7AM - 7PM Central Time
7 days a week
Feb 02, 2011 | Rheem Tankless Hot Water Heater...
Toyo stove laser 73 throws a EE 2 code and back fan will not come on.
EE 2 can be caused by a couple of things but is usually a fuel issue or a flame rod problem. The circulation fan will not come on until the burner has warmed up. The combustion blower should start almost as soon as you turn the heater on. Turn the heater on and listen for the combustion blower. If it doesn\'t start, do you get an error code? If the blower started wait for the fuel pump to come on. It will start when the burner lights come on. If the fuel pump makes a loud ticking or thumping sound, it isn\'t getting any fuel. Check the fuel filter and the strainer in the fuel sump. Make sure the valve is turned off at the barrel before removing the fuel strainer. If the fuel pump is working normally, does the heater light up. If it doesn\'t, check the igniter. You can check that first if you want and have a clamp on ammeter. Place it around one of the igniter leads and you should read 2 to 4 amps when you turn the heater on. If the heater does light but then cuts off after about a minute, clean the flame rod. Unplug the heater before removing the flame rod because it may kill the circuit board if the heater is plugged in and the flame rod touches ground. Let me know what you find.
Jan 18, 2011 | Rinnai Toyostove Direct Vent Heater:...
Heating & Cooling Logo
140 people viewed this question
Top Rheem Heating & Cooling Experts
jeff5may32
billconfused
Lawrence Oravetz
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
