Question about Husqvarna Garden
The carburetor on my Husqvarna YTH2148 is not getting gas
I have gas in the tractor but it's not flowing to the carburetor, I see a small amount of gas in the fuel line. Does this model have a fuel pump or is it gravity feed?
wadembly
  • 513 Answers
SOURCE: Hard start or won't start
the float in the fuel bowl might be getting stuck what you can do is push & pull on float to see if it flows if not the replace the float if i can help further e-mail me wade @ wadembly@aol.com
Posted on Jun 28, 2009
SOURCE: I have an 18 HP Craftsman tractor (model
The pump is not good,to test it,you take out the out fuel pipe start the engine ,see if fuel is coming out fully to the pipe,if sometimes it comes and cut,this means the fuel pump is not working properly.You have to change it.
Posted on Sep 06, 2009
Testimonial: "Thank you so much for you quick responses. My tractor is back up and running!"
mickey813
  • 472 Answers
SOURCE: steering gear on my Husqvarna YTH2148 tractor is
you have to take the whole dash off to get to it it bolts frome the bottem
Posted on Feb 07, 2010
  • 3911 Answers
SOURCE: Can't get our Husqvarna YTH 2148 lawn tractor to
On my YTH2148 you take off the air cleaner and then the backing plate for the air cleaner and the carb is right there. If memory serves me there is a drain hole on the bottom of the carb, you can unscrew the drain bolt and the old gas is gone.
Posted on Apr 05, 2010
mickey813
  • 472 Answers
SOURCE: Poulan Pro 20hp Tractor with B&S fuel flow problem
sound like to m e that your gas cap is bad if its not venting it will do that
Posted on Apr 16, 2010
Gas leak from bottom of carburator. backfier
If mower has been put up for winter and old gas left in gas tank it will drain to carburetor and the float will stick. This will let the gas flow out the float bowl. Remove float bowl and use carburetor cleaner to clean the valves and move the float up and down when it you get it clean the gas should flow float down and turn off when pushed up.
B. J.
Apr 09, 2014 | Husqvarna 24HP VTwin Hydrostatic 54" Cut...
Engine misfire
Mowers aren't my forte but it sounds likt the valve clearances need checking. Here is a link to a description of how to correct the valve gaps.
May 01, 2013 | Husqvarna Lawn Tractor Yth2148 Owners...
My Husqvarna will only stay running with the choke in and even then it will only run for a short time?
Gas flow through the carburetor is clogged. Easy fix is the following----- remove all gas from tank (siphon or drain). Put that gas aside or dispose of it. Use a little bit of fresh gas and a little bit of carburetor cleaner in the tank. Run that through (by running the motor with the choke.). Do it several time if needed. When it seems to be running better, then try just a little gas only to be sure you have cleared it. When you fill-er-up, be sure to add a gas additive like Sea Foam or similar.
Apr 29, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Can't get our Husqvarna YTH 2148 lawn tractor to start this year. I suspect it's old gas in the carburetor. Drained the remaining gas from tank and added new and everything else looks good. Battery &...
Apr 05, 2010 | Husqvarna Garden
Jun 28, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
