My printer is always offline
I am always having to shut it off and start over but now it is constantly offline. It is very unreliable.
  • 5 more comments
  • Anonymous Feb 02, 2009
    printer offline and can't print
  • Anonymous Feb 12, 2009
    I have an assignment due into uni tomorrow and my printer started this just as I was trying to print it off. What am I going to do??
  • barretti Feb 25, 2009
    I have several users attached to a label printer and some of those users go offline. I have to reinstall the software to make them work again. What can I do
  • Anonymous Apr 06, 2009
    prints fine, after being left alone for about five minutes it goes offline and i have to turn it off/on to get it back online.
  • Anonymous Apr 10, 2009
    Same exact problem.
  • Anonymous Apr 30, 2009
    always go offline my printer hp 370
  • mcubtpn Apr 30, 2009
    Printer properties Always set Offline
If your account is member of the administrators group try to right clic the printer and select the option use this printer online; else ifyou are logged with a standard user account, press the shift key of the keyboard, then right clic the printer and select the option run as ... then select the option use this printer online. the runas dialog box is dispayed then enter the administrator credentials.
Posted on Dec 16, 2009
2 Suggested Answers
SOURCE: printer won't print it always it is offline...
Perform the steps below and check
(1) Click "Start" > "Run".
(2) Type "services.msc".
(3) Click "OK".
(A window will pop-up with so many services listed)
(4) Locate and Right-click "Print Spooler" entry and Select "Restart" from the drop down menu.
(5) Now please restart the computer.
* Click Start > Control Panel > Printers
* Select the Printer you are using
* Right Click on the Printer Icon
* Select Use Printer Online
Now check if you are able to print
Posted on May 20, 2010
Message says printer is offline
Sounds like your usb connector or cord. When you change the printer to a different usb outlet you may have to go to control panel and select the printer as the default printer. Always use the same plug if it works good.
Nov 24, 2013 | HP LaserJet Pro P1102W Printer
I made some copies last week and now my printer won't print. It keeps saying it is offline. I've turned it off, changed ports into the computer, shut the computer down, and tried most of the things I can...
  • Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
  • Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
  • Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
  • Read more: How to Change a Printer from Offline to Online ' eHow.com http://www.ehow.com/how_4796279_change-printer-offline-online.html#ixzz16oE47d1K
    Nov 30, 2010 | Canon PIXMA MP780 All-In-One InkJet...
    Maintenance code TA does the printer go offline
    Ok so the TA code means that the all maintenance counter has reached its limit
    To clear this you need to clear this easy you want
    # , * , c , *
    To enter service mode
    Type in code 24 press start
    Then you want sub code 04
    Then you can select what you want to clear so the maintenance count all
    Execute this yes then press the CA key the machine will restart and away you go
    I also do advise that you service representative comes along at some point to check the machine it could need parts because if you stretch the life of parts your machine could become unreliable... But that is up to you.
    Jun 05, 2010 | Sharp MX-2700N Color Copier
    Printer won't print it always it is offline
    (3) Click "OK".
    May 18, 2010 | Office Equipment & Supplies
    The printer is always offline
    try this go into control panel click on printers to open all available printers. make sure your printer is set to default. right cilck on your printer a menu will appear look for use printer online and click on it if its a setting this will fix it. if not uninstall and then reinstall the printer software with your antivirus disabled
    Oct 25, 2009 | Lexmark All-in-One Printer with PictBridge
    Printer always says its offline even though its on and connected
    If you are Windows XP Operating System, perform the steps below:
    1. Click Start --> Printers and Fax.
    2. Right click the printer icon and check the following:
    a. Check whether the All-in-One is set as default printer.
    b. Ensure that the there is a check mark on the "Use printer online". If you have the Use printer offline, make it online by selecting the option.
    c. Ensure that there is no check mark on the Pause printing.
    Check for the default printer and USe printer Online in the printers and faxes folder.
    Click Start -->> Control panel -->> Hardware and sound-->> Printers-->>Change default printer. ---> Please Right Click on the printer icon which has tick mark and Select the options Use printer Online and Set as Default and also Select the option Resume printing.
    Sep 30, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
    My printer is always offline how can i set it online?
    Go to start - printers and faxes - then right click on the printer, then click on offline. That might do the job.
    Jul 30, 2009 | Lexmark X4650 InkJet Printer
    Printer is offline
    go to Start... click Run .... type services.msc and find print spooler right click stop and click start again
    Jul 16, 2009 | Konica Minolta bizhub 161f All-In-One...
    Printer's Offline
    go to start and control panel, choose option for Printers and under that you will see the Printer listed. You just have to make a right click on the Printer and choose option "USE PRINTER ONLINE"
    May 19, 2009 | HP Deskjet D2360 InkJet Printer
    Printer status always offline
    go to your programs and select printer and faxes..rigth click your printer icon and select use this printer online..and if you want make this printer to be a default printer select also use this printer as default..
    May 18, 2009 | HP DeskJet 3940 InkJet Photo Printer
    1,615 people viewed this question
    jasbo
    jasbo
