Question about Rheem 80 GAL ELEC TALL Water Heater 6YR SC 82V802
Heating element cycling on and off fairly often
Every time we run hot water anywhere in the house the hot water tank will cycle on. even if the water is run for only a few seconds. would like to know if this is normal or adding to the high cost of our electric bill. the tank was just installed in november of 2008 in a newly constructed house.
  • 90 Answers
Yes, unfortunelty elextric water heaters do cycle a lot. They are a little bit different from gas water heaters, in the fact that they run differently and seem to run out of hot water faster, then gas water heaters. Just make sure, that the thermostat is set at 120 F. The thermostat will be behind a panel, and under the electrical wire connections. You will have to use a flathead screw driver, to change the temp. settings, if they need changing. Also, make sure that once a year, that you flip the Pressure relief valve to equalize the pressure and to drain at least 2 gallons of water out of the tank.
Posted on Jan 20, 2009
The power button wont come on to heat
Troubleshooting a Tank-Type Water Heater That Won't Start ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
Whether your water heater runs on gas or electricity, it needs a controller to cycle theheat on and off, or the water in the tank would either be stone cold or ... If the buttongoes in and stays in, the thermostat should start working again. ... Screw in a new element, reconnect the wires, refill the tank and turn the power back on.
Troubleshooting Electric Water Heaters in MINUTES ~ Step ...
? 7:01
https://www.youtube.com/watch?v=SlyStHM9Nr0
Oct 4, 2013 - Uploaded by electronicsNmore
AFTER you establish that there is power being supplied to thewater heater .... When the water is cold in the tank the top element will come on first, heating the ... is overly hot and then notice no hot water check the reset button.
Tanklets: Electric water heater problems
Jan 25, 2016 | Water Heaters
How to replace water heater element will water cme out when you remove element does tank have to be drained
Safest method:
Shut off electricity to heater.
Shut the water valve.
Drain heater to below the level of the element, open hot water valve in house to vent heater to speed draining.
If the element is on top, you don't have to empty the heater.
Remove old element, install new element.
Leave hot water valve open somewhere in the house.
Turn water on.
Once air is removed at hot water valve, turn electric on.
Shut water valve.
Gary
Aug 13, 2011 | Reliance /State Ind. 9002450 Element For...
Water does not get hot in dishwasher and the dishes are not dry at end of cycle
your heating element might be burned out.
a local appliance house may stock what you need or order it for you. they might even explain how to replace it
Aug 04, 2010 | Whirlpool Dishwasher Water Heater...
Hot water does not last long. Hot water heater is a 50 gal ge smart water heater. It takes a long time to heat and is not very hot when it reaches shower in the back part of house. Where are the coils or...
probably has a bad heating element. May be a little limed up also. Drain the heater and replace the elements. Take a special tool to remove and replace the elements. ( fairly cheap) You can probably get the elements and parts at a good hardware store. The people at the store probably will explain to you how to replace them. Feedback please if this was of help
Feb 20, 2010 | General Electric GE SmartWater Household...
Warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Sep 16, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have had a PowerStar A125 for about a year and now the water is hot in the beginning and goes cold and then hot again. I have observed the light when the shower is on it cycles on and off. My wife wants...
If on a well, you can install a regulating valve in the line to help with this problem. You may have to play with the valve a little to find the right pressure to avoid those highs and lows. I installed a Bosch A125 and had this problem from the start. A little research un-earthed the regulating valve (I think around $25 at Lowe's or Home Depot) and we have had even hot water ever since.
Jun 15, 2009 | Bosch PowerStar AE125 AE125 Whole House...
Top element only working
How they work. First you need to know that cold water goes into the tank near the bottom (because of the "dip tube" inside the tank) and hot water is taken out at the top. Also hot water naturally rises.
so... when the tank is full of cold water the top element will come on and heat up the top 1/3 of the water then the bottom element will come on and finish heating the rest of the tank.
so... set them both at the temperature you want the water to be... about 120^F.
Apr 02, 2009 | Water Heaters
Will I get power to both elements at one time I test power at elements while unit is heating and can only get power to one element at a time.When one thermostat cycles off the other element will come on.I...
You are correct. That is the way most of the two eliment  water heaters work, one eliment at a time. Make sure that the two thermostarts are set at the same value. Have you tried just making the water hotter, so that the hot water will not be used at such a fast rate, when mixed with the cold? Also draining the sediment from the bottom of the tank with increase the water capacity,of course.
Mar 10, 2009 | Water Heaters
Leaking tp valve
It is time for a New Water Heater.....But there are a few steps you can take to "TROUBLE SHOOT" the situation. There is a Drain Valve at the Bottom of the Water Heater. You may have a build up of ....gunk...at the bottom of your water heater, if you have a floor drain in a basement or some way for the water to drain, than you can carefully loosen the drain at the bottom of the tank to FLUSH the tank.....The other option will still reqiure draining the tank and replacing the heating element.. My best Solution is to make sure the bottom of your Mobile home is Insulated Properly From the Wind and Elements. Even Bails of Hay stacked around your Foundation Can be VERY Effective.....MOSTLY THOUGH I THINK IF YOU DRAIN THE TANK AND REPLACE THE HEATING ELEMENT, your problem will be over, With proper Insulation under the Mobile. This has worked for me a few times..... Hope it helps.....Joe
Jan 10, 2009 | Water Heaters
Rheem 80 GAL ELEC TALL Water Heater 6YR SC 82V802 Logo
85 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
